intake manifold 99flstf
Old Mar 25, 2020 | 07:56 PM
amd's Avatar
amd
Stage IV
Default intake manifold 99flstf
This may be a stupid question but does anyone know what size a stock manifold is for a 99 evo softtail? I'd like to get a new carb and want one that will slide into the existing intake.
Old Mar 26, 2020 | 08:11 AM
0maha's Avatar
0maha
Mods should have moved this to the Evo section.
What makes you think you need a new carb? There's nothing wrong with the Keihin CV that came on the bike. At most, pull it apart, give it a good clean, replace all the soft bits and you're golden.
There are two popular aftermarket carbs. The Mikuni will use your stock manifold. The S&S comes with it's own manifold.
Old Mar 26, 2020 | 09:31 AM
amd's Avatar
amd
Stage IV
thanks much!
Old Mar 26, 2020 | 09:37 AM
amd's Avatar
amd
Stage IV
my original keeps over flowing. I change out everything and was careful with the correct float position but still no success. Maybe I had the wrong rebuild kit? Any suggestions are appreciated. I'm building a chopper but you can probably guess I'm not a mechanic.
Old Mar 26, 2020 | 10:48 AM
0maha's Avatar
0maha
Take a Q-Tip, dip it in polishing compound, then use it to polish the seat where the needle valve lands.
This article from CV Performance has some good info: https://cv-performance.com/cv-perfor...tor-fuel-leaks
Old Mar 26, 2020 | 12:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Get your carb parts from a good source, Omaha has you pointed in the right direction with CV Performance.
There are a lot of substandard parts out there on the internet, especially Carb stuff.
Deaf_N_1_Eye
Jan 6, 2015 11:31 PM
polish hammer
EVO
Mar 3, 2014 05:56 PM
Mikey Ashie
Dec 10, 2012 06:23 PM
NutterFLH
EVO
Feb 18, 2011 02:28 PM
Jameson
Mar 18, 2007 03:52 PM
