Carb Size for EVO
Old Mar 17, 2007 | 08:03 PM
Jameson's Avatar
Jameson
Default Carb Size for EVO
Id like to upgrade my Carb on my EVO but not really sure which size is the best for me. 42mm or 45mm. Also not sure about the brand name? Mikuni, S&S or Edelbrock? And specific Jet to look for etc. Do any come pretty much tuned out of the box except for minor adjustments like Carbs for a car? Thanks.
Old Mar 17, 2007 | 08:17 PM
txfxstrider's Avatar
txfxstrider
Default RE: Carb Size for EVO
I am a fan of the S&S Super E. I have one on my Evo. They come, as you say, pretty much set up and just require minor adjustments. Fairly easy install. Kit includes intake manifold, carb and air filter assembly. You will also need to change your carb cables. A nice Saturday project. You will feel impressive results if you are now running a stock carb. Also change your stock mufflers if you have not already. You need a free flowing exhaust to benefit from a free flowing intake.
Old Mar 17, 2007 | 08:23 PM
JB's Avatar
JB
If you get youre stock CV set-up right it's good up to between 90 & 100 hp. They are a damm good carb when you get them set-up. right.
Old Mar 17, 2007 | 08:25 PM
Jameson's Avatar
Jameson
And how exactly do I set them up right?
Old Mar 17, 2007 | 08:33 PM
JB's Avatar
JB
When I did the motor work on my 87 which was over bore cam and some head work I took the carb and went with #180 main jet, #50 low speed jet drilled the vac.hole on the slide polished the slide and the throat were the slide runs and cut 3 coils off the slide spring.
It has run great don't have to use the enricher till it gets down to about 60 deg. and haven't fouled out a plug yet.
Old Mar 17, 2007 | 08:38 PM
Jameson's Avatar
Jameson
WOW, I guess im not a carb mechanic because the only part I really understood how to do was the jets. ANy special tools required? A write up I could fin that shows how to do this type of rebuild. PArts list and where to find the parts? Id love to not have to use the enrichner.
Old Mar 17, 2007 | 09:08 PM
JB's Avatar
JB
The only parts you would need to buy would be the jets. You really don't need to polish the slide I just sort of did it for the hell of it. Ill see if I can dig up some pic's of the rest for you.
Old Mar 17, 2007 | 09:15 PM
JB's Avatar
JB
Here is a pretty much step by step. Its down in the DYI section.
https://www.hdforums.com/m_149206/tm.htm
Old Mar 17, 2007 | 11:39 PM
EVOrider's Avatar
EVOrider
S&S Super E
Nothing to ever go wrong with this carburetor. I have had so much luck with these. I always got bettery fuel mileage and there are more adjustments on this carburetor.
I am not saying the CV is a bad carburetor, you can make these work well if tuned right. However, I believe the S&S will outperform the best tuned CV.
Old Mar 18, 2007 | 03:52 PM
mentor70's Avatar
mentor70
Head-Quarters offers a CV tunning kit with the right gettting for a warmed up stocker or a big bore engine.
I would not recomend to do any drilling or tampering with the CV other than pulling the Idle mixture cap to acess the screw.
If you really want an aftermarkt card, I use a Mikuni 42. Less air restriction over a $&$ stuper E and an all around better fuel mixer.
Pothole914
EVO
Sep 13, 2016 10:55 AM
98fxdwgcmc
EVO
13
Jul 22, 2016 12:34 PM
VTwinJaxFL
Exhaust System Topics
16
May 28, 2016 10:20 AM
polish hammer
EVO
Mar 3, 2014 05:56 PM
Hank Johnson
Jun 13, 2013 09:38 PM
