Loud Metal Clanging
Old Apr 13, 2020 | 11:59 AM
4OH6's Avatar
4OH6
1st Gear
Default Loud Metal Clanging
I have a 2007 Sportster 1200L and it was perfectly fine until a dead battery slowed down my riding, and while charging, I replaced the spark plugs with some NGK Iridium plugs, and now when I fire it up it runs but there is a god-awful metal on metal clanging going on and I'm having a hard time figuring out where it's coming from. Any insight helps. Cheers!
Old Apr 13, 2020 | 12:28 PM
memphisharley's Avatar
memphisharley
since you only changed the plugs can you verify the new plugs vs the plugs you removed as far as length in the hole.
Old Apr 13, 2020 | 12:37 PM
4OH6's Avatar
4OH6
1st Gear
Before I put in the new ones, I double checked that they were of similar length and they are.. I still have the old plugs, should I put them back in to see if anything changes?
Old Apr 14, 2020 | 07:23 AM
deperdue's Avatar
deperdue
Most definitely, when in doubt always undo the last thing you did before the problem showed up
Old Apr 14, 2020 | 07:51 AM
Super Glidester's Avatar
Super Glidester
Did you not tighten something up upon reassembly.? Also is it clanging sitting still or when riding? Things to tighten up? The seat , the sissy bar? isnt there a bracket holing the battery in? there is a cover for the battery, anmd anything else that you may have ratcheted bolts out of etc.
Old Apr 14, 2020 | 03:47 PM
djl's Avatar
djl
Hard to help without being able to hear the noise but don' think it's the plugs.
Old Apr 14, 2020 | 04:36 PM
eighteight's Avatar
eighteight
if it is plug length the OP can leave them in and run it , that will definitely make the noise go away....
lh4x4
VRSC Models
May 13, 2017 11:57 PM
477966
May 1, 2016 07:18 PM
hardballcoaster
Apr 10, 2014 04:00 PM
emc12
General Topics/Tech Tips
Jul 31, 2012 08:01 PM
biker_chick
Jul 5, 2010 09:41 AM
