Spun rod bushing ?
Old May 10, 2020 | 06:50 PM
Jackie Paper's Avatar
Jackie Paper
See this on a Softail but it had a 100K on it. You have an alignment issue in your build. However anything will break if you beat on it hard enough.
Old May 10, 2020 | 07:21 PM
Max Headflow's Avatar
Max Headflow
I would also say that since you seized the front piston, check the piston oiler. Might want to replace it as you'll be pulling the crank anyway. How many miles since the last build. It could also simply be a bad tune.
Indy Road Dog
Engine Mechanical Topics
16
Aug 1, 2021 05:48 PM
GibsonSG
25
Jun 13, 2020 10:06 PM
BobRR
Apr 8, 2019 12:44 PM
tomlescal
Exhaust System Topics
Feb 21, 2014 12:01 PM
NamVet69
Jun 11, 2013 08:20 PM
