Cam replacement recommedations
Old May 11, 2020 | 08:34 AM
bcarrot28's Avatar
bcarrot28
1st Gear
Default Cam replacement recommedations
I pulled my 86 fxr down to replace lifters and found a sifton 141 "warrior" cam. Is this a decent cam? I am unsure of the rest of the engine combination since I bought it used however I do know it has ported heads and higher compression pistons, unsure of bore size or stroke. It has a screaming eagle replacement carburetor and 2 into 1 exhaust. If this is not a decent cam can anyone point me in the direction of a suitable replacement? Sorry for the vague information but it is all I know at the moment. Thanks for any help.
Old May 11, 2020 | 08:56 AM
Yankee Dog's Avatar
Yankee Dog
Take a look at this thread:
https://www.hdforums.com/forum/gener...or-97-evo.html
Hope the link helps. YD
Old May 11, 2020 | 10:26 AM
ScottinAZ's Avatar
ScottinAZ
this site has info on a bunch of cams for Harley motors. Scroll down into the Evo section, and you will find the specs on the Sifton 141 cam you have. You can then compare it to others that you are thinking about. Hope this helps
http://www.nightrider.com/biketech/HDMasterCamSpecs.pdf
Old May 11, 2020 | 04:58 PM
eighteight's Avatar
eighteight
[QUOTE=bcarrot28;19107900]I pulled my 86 fxr down to replace lifters and found a sifton 141 "warrior" cam. Is this a decent Cam?QUOTE]
You have any seat time on this bike/ engine build?
If yes, then you are the best judge of how it works/ runs/ performs
If no , then back to the regularly scheduled program
jmd897
Engine Mechanical Topics
14
Jun 14, 2019 11:27 AM
theduroche
EVO
Mar 30, 2019 11:36 PM
187
Nov 18, 2013 08:05 PM
legacycycles
EVO
43
Jan 24, 2010 02:09 PM
gargoyle
Exhaust System Topics
Mar 7, 2008 08:09 PM
