frustrated
Old Jun 15, 2020 | 09:15 AM
velson's Avatar
velson
Stage II
Default frustrated
Hi al,l need help i have been getting sputtering some times at idle it will sputter and bog out and also some times sputter and blow out at the carb when ridding then i throttle up and it will go away and it will happen again at some point
Old Jun 15, 2020 | 09:18 AM
velson's Avatar
velson
Stage II
oh sorry did not mention it is a 2006 Road King EFI
Old Jun 17, 2020 | 05:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Sounds like a lean condition.
EFI dyno tuning would be our approach, once we determine all else is sound.
Scott
Old Jun 17, 2020 | 08:55 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
First off you state "blow out at the carb" but as I recall no 2006 models had a carb. If it's EFI, has it always done this or is it something new? 2006 was a bastard year that had low speed running issues and HD use to replace the injectors and calibration for free in them. The free replacement has long since passed, so your on your own. The original bikes had an injector part number that ended in -06 and the replacement injectors are -06A. These are two completely different injectors and require a different calibration. Your going to have to check yours and see what you have before doing anything else.
Old Jun 17, 2020 | 09:13 PM
TwiZted Biker's Avatar
TwiZted Biker
Intake leak, screws with all the sensors needed to balance the EFI. Changing spark plugs wouldn't hurt either.
Old Jun 17, 2020 | 09:59 PM
ahern25's Avatar
ahern25
Was some modifications done before this all started?
Old Jun 18, 2020 | 05:30 AM
Hillsidecycle.com
Sponsor
Classic symptom of fuel starvation.
Scott
32vld
Carburetor Related
Apr 17, 2020 11:06 AM
Tweeter07
Exhaust System Topics
Mar 10, 2014 12:49 PM
magnum629c
Apr 5, 2010 10:39 PM
fastjoe
Oct 3, 2009 01:01 AM
kd4tsc
Apr 29, 2009 08:11 PM
