2017 103” engine and cam questions
Old Jun 30, 2020 | 05:27 AM
prodrag1320's Avatar
prodrag1320
Originally Posted by djl
From what I read, 800rpms is as low as you can go and maintain a proper rate of charge to the battery but unless the motor is idling all the time, I don't see how that is a problem since the motor doesn't idle very long when it is idling. Anything below 800 rpm will probably be hard to maintain idle at that rpm with a carbed motor but should be easier to maintain with an EFI motor. I know my built, carbed all bore 107 would never maintain idle at 800 rpms.
I don't see the harm to set idle at 800 rpms if the motor will maintain it without dying.
800 rpm idle will take out the rod bearings
Old Jun 30, 2020 | 05:57 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
A "comfortable" idle can be different from one engine to another, depending upon what has been done.
You can hear it, and to set it to a tach reading sometimes does not apply.
Too low is bad for a couple reasons.
For instance, our race bike didn't "like" it much below 1600-1700.
Would it idle lower?...yes....did it like it?...no.
Scott
Old Jun 30, 2020 | 10:26 AM
twincam10353's Avatar
twincam10353
Sorry to hijack the thread, when I purchased my Thundermax ECM it was sent to me "pre-mapped" for my Stage 1 103HO. The idle RPM was/is set to 896. Mind you, this only applies when the motor is idling at operating temperature. I don't think you can adjust the "cold" idle RPM with the TMax.
Old Jun 30, 2020 | 12:09 PM
60Gunner's Avatar
60Gunner
Scott
I assume because you also had the timing advanced pretty good? I keep my rpm up and run some pretty advanced timing. Seems to really like it.
steves86ta
Engine Mechanical Topics
Aug 21, 2019 01:42 PM
Mikeduke108
Aug 5, 2014 04:39 PM
ebeattie
May 19, 2013 06:43 PM
thor10000
Mar 15, 2012 06:00 AM
BadBagger08
Exhaust System Topics
Sep 17, 2011 02:24 PM
