Cranks, but will not run
Old Jul 20, 2020 | 01:38 AM
snuff2000's Avatar
snuff2000
Default Cranks, but will not run
Good evening everyone. I have a 14 street bob and just replaced the drive belt after having it snap while on the road. Bike is back together and everything looks and feels good. Went to start it and it cranked over twice before misfire. Looked at wiring to make sure all was good. Went to start again but only cranks, engine turns over and tries to start but just cranks and pops every few cycles of the cylinders. Not sure where to go from there. Tried doing research but only getting info for crank no start, but most deal with starter issues or plugs. Nothing really involving replacement of belt and now crank non start (running). Any info would be great. Thank you.
Old Jul 20, 2020 | 01:28 PM
Mattbastard's Avatar
Mattbastard
What all did you take off or disconnect before swapping out the belt?
Old Jul 20, 2020 | 01:30 PM
djl's Avatar
djl
Sounds like plug wires are backwards. Were they disconnected during the belt change process?
Old Jul 20, 2020 | 08:51 PM
Ed Ramberger's Avatar
Ed Ramberger
You beat me to it.
Old Jul 20, 2020 | 09:24 PM
Screamin beagle's Avatar
Screamin beagle
Plug the coil back in? Did that once, figured it out after 10 minutes of panic
Old Jul 21, 2020 | 11:16 AM
Ed Ramberger
It wouldn't pop of the coil was disconnected
BigDogBigJim
Shovelhead
Mar 26, 2014 06:38 PM
Huskerjim
Exhaust System Topics
Nov 20, 2013 03:53 PM
Huskerjim
Nov 2, 2013 09:23 AM
ta2dup
EVO
13
Jun 17, 2012 07:05 PM
badmfr1
Aug 25, 2006 11:22 PM
