Evo cam change - missing part?
Old Jul 20, 2020 | 08:56 PM
joe40x's Avatar
joe40x
Huh, It would seem that I am wrong(as usual as my wife says) This thrust washer "disappeared" in the 1991 models. It's listed in the 1990 parts book but not in the 1991 and up. I'd still put one in.
Old Jul 21, 2020 | 08:03 AM
Adam76's Avatar
Adam76
At some point that spacer was left out...
The worst mechanics on the planet are known as "Previous Owner"....
Ok, I found out today that they replaced the shaped/angled thrust washer with the dog ears in around 1991/2 to the simple flat round one found in the later models. It's possibly a cost cutting change? Because from what I have understood the later model round ones are prone to spinning with the crank and wearing against the inner case, whereas the older style had the dog ears that held it in place...... Don't know why they would have changed it?
Old Jul 22, 2020 | 07:28 AM
wfolarry's Avatar
wfolarry
It disappeared when they changed everything in the cam chest.
Early motors had a tapered pinion shaft
Late motors had a straight shaft.
If you look at the 2 photos you can see the difference in the gear arrangement
The early cases had that small chamber in the lower left hand corner. Later cases it was all open.
You can't mix & match.
Old Jul 22, 2020 | 07:34 AM
Adam76's Avatar
Adam76
THANKS wfo Larry. That's cleared that up. I was about to order one.
brad75raiders
Engine Mechanical Topics
18
May 5, 2018 08:45 PM
Howe09
EVO
Jul 14, 2013 03:42 PM
gsxrboy96
Mar 25, 2012 03:04 PM
JohnFlorida
"The Florida Crew"
Jan 27, 2012 07:02 AM
kandfirsthd
May 16, 2011 08:08 PM
