98 FLSTC EVO cam
Old Jul 7, 2013 | 04:39 PM
Howe09's Avatar
Howe09
6th Gear
Default 98 FLSTC EVO cam
I bought my first Harley about 6 months ago and I recently learned the Evo engine has a problem with the cam bearings. I don't know if the previous owner replaced the cam and bearings so I was wondering if there is a way to tell. I can't ask because the previous owner is deceased. Are there markings on an aftermarket cam to identify the manufacturer?
Old Jul 7, 2013 | 04:44 PM
Bumpandrun's Avatar
Bumpandrun
How many miles on it?
Old Jul 7, 2013 | 04:53 PM
Howe09's Avatar
Howe09
6th Gear
The odometer lcd is cracked so I have no idea. could be 5000 could be 50000.
Old Jul 7, 2013 | 05:23 PM
panz4ever's Avatar
panz4ever
What you want is a "Torrington" made cam bearing. Only way to tell is to pull the nose cone, electronic ignition assembly, and cam.
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Do you have acceleration in 5th gear?
If yes then you probably have an aftermarket cam.
The only way to be sure if the cam bearing has been changed is to open her up and take a look.
Old Jul 7, 2013 | 05:45 PM
Howe09's Avatar
Howe09
6th Gear
I planned on opening it up but I was hoping for identification on an aftermarket cam. I would think if the cam was replaced surely a $7 bearing would be too. I know torrington will be stamped on the bearing race but will I be able to read it with out pulling the cam? I do accelerate in 5th, with ease, though there is a dead spot in the mid range rpm area. if I slowly accelerate at about 70-75 mph. it boggs down a bit before kicking in. I have a s&s super e on it.
Old Jul 7, 2013 | 06:43 PM
texashillcountry
Dirt don't hurt
I would think so but there is no guarantee they changed bearings.
You might have to adjust your carb to get rid of the flat spot.
http://www.millerscustomparts.us/san...tuningtips.htm
Old Jul 7, 2013 | 10:05 PM
traildog's Avatar
traildog
Yes, and it's IMPRESSIVE!
Old Jul 8, 2013 | 08:18 AM
ironoxide's Avatar
ironoxide
Default adjustable push rods
The presence of adjustable pushrods could provide a clue that some work may have been performed in the cam chest.
Old Jul 9, 2013 | 05:43 AM
Howe09's Avatar
Howe09
6th Gear
I got a gasket yesterday, and plan on opening her up this weekend. I have been doing the debate over the pushrods. How often do you have to readjust the adjustable ones?
And how do you know when it's time to adjust?
