TC 96” cam choices
Old Jul 22, 2020 | 11:44 AM
Craspy's Avatar
Craspy
Originally Posted by dfwhockey17
Years ago I helped a buddy out with his '08 Ultra Classic he had just bought. We installed some parts I had around the shop to 'get him more power on the cheap'. I put on the small/cheap Cobra 2-1 exhaust, a HPI Billet Pro air cleaner and we threw in a set of 48's I had on hand. That bike made 81hp and 101tq (tuned with Direct Link on a fairly conservative dyno). Since then we have installed numerous sets of 48's in 96's and 103's, they are a great bolt in cam!
Alll I hear are good things about that cam.
When I get the work done. What else should I be changing. Lifter and pushrods. Bearings. How about tensioner or anything else. Thanks.
Old Jul 22, 2020 | 12:11 PM
Craspy's Avatar
Craspy
Default Cam swap additions
Better question is do I need to go with a hydraulic tensioner or is the spring fine.
bike has under 10k miles
i would change lifters, pushrods, bearings and gaskets. Am I missing anything else?
thanks
Old Jul 22, 2020 | 12:54 PM
Pachuco's Avatar
Pachuco
I have the EZ583 cams in my 2010 96" and it is the best thing I have ever done to the bike. The easy start feature is well worth the money. Shouldn't the 2011 have hydrolic tensioners? Mine is 2010 and has them.
Old Jul 22, 2020 | 01:46 PM
Mattbastard's Avatar
Mattbastard
Originally Posted by bigal51
With the S&S ez start cams your paying over $100. for technology you don't need in a bolt in cam. The Andrews 48 tunes in great and no problem with hot starts if it's tuned properly.
What does tune have anything to do with how a hot engine cranks over?
I roundly recommend the EZ start cams if you don't have compression releases, even on a stock 88" engine. That design makes so much sense I'm left wondering why it took Harley so long to incorporate it onto their engines. Other manufacturers of big engines have been using mechanical means to lower cranking compression for years. It took Harley til the 103" to start using it and they went with solenoids.
FYI, that S&S design is so good Indian uses it on ALL their camshafts.
Old Jul 22, 2020 | 01:55 PM
todd-67's Avatar
todd-67
thanks
Your 2011 has hydraulic tensioners in it. Nothing to do there. It's as you stated, push rods, lifters, gaskets, and inner cam bearings.
Old Jul 22, 2020 | 02:03 PM
Qdog002's Avatar
Qdog002
I also leaning that way.
No doubt the 48 is a great cam but I like the idea of the ez583 cam because the 96" does not have ACR`s.
Old Jul 22, 2020 | 02:36 PM
Craspy's Avatar
Craspy
yes. Thanks sir.
Old Jul 22, 2020 | 02:38 PM
Craspy's Avatar
Craspy
definitely another good reason. Thanks.
Old Jul 22, 2020 | 03:17 PM
djl's Avatar
djl
A Stage I 96" with stock heads and head gasket running the 48 cams, CCP will be about 185psi; just a tick above stock; compression not an issue unless one wants to make it an issue.
Old Jul 22, 2020 | 03:37 PM
60Gunner's Avatar
60Gunner
Or the 570s. Designed for the 96".
