Oil line replace trick?
Old Aug 2, 2020 | 08:19 AM
Riffraff123's Avatar
Riffraff123
Default Oil line replace trick?
Is there a trick to getting the oil lines back in to tank? Changed starter clutch and put everything back together and hard lines were REALLY difficult to get back in.
Like they were lining up crooked. I had the oil tank loose and the rear exhaust loose. I killed one of the o rings trying and have a leak now.
I got new o ring kit at dealer and their service guy recommended putting O rings and spacer on the hose end 1st instead of in the tank like manual and all the videos show.
what say you guys?
Old Aug 2, 2020 | 08:30 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Model and year....
Old Aug 3, 2020 | 05:23 AM
Riffraff123
2000 flstc
Old Aug 3, 2020 | 08:51 AM
m1369x's Avatar
m1369x
Have to kind of gently manhandle it to line it up , The braded flex in the middle will handle it
Old Aug 4, 2020 | 12:19 AM
Riffraff123
Model and year....
Sorry..I get writing and forget that not everyone on here knows what I ride. It is the bike in my sig.
Old Aug 10, 2020 | 08:48 AM
bvandenberg's Avatar
bvandenberg
6th Gear
I had the same problem. I ordered a new OEM clip and the new clip came with a plug, o-rings and spacer. You push the plug, clip, o-rings and spacer into the tank and then remove the plug. This plug sets the o-rings and spacer into the correct position in the tank. Then the oil line assembles into the tank hole very easily,.
Old Aug 10, 2020 | 02:16 PM
m1369x's Avatar
m1369x
Cap/plug is just for transport
Remove plug , slide onto oil line push oil line with plug installed into tank , You may have to gently man handle oil line to line it up
Old Aug 11, 2020 | 08:18 AM
bvandenberg
6th Gear
m1369x
That is not correct the plug is used to insert the clip, o-rings and spacer. You put the assembly into the the tank, then remove the plug. This leaves the clip, o-ring ans spacer installed in the tank. Then just insert the tube into the clip.
Old Aug 11, 2020 | 08:25 AM
m1369x's Avatar
m1369x
Originally Posted by bvandenberg
m1369x
Correct or not It's worked for me every time on several occasions , Any way if you knew , Why Ask?
P.S. Thanks
Old Aug 11, 2020 | 08:27 AM
bvandenberg
6th Gear
No reason to get snappy,. I was just trying to help the OP with his question.
