Oil line replace trick?
Old Aug 18, 2020 | 07:00 AM
Riffraff123's Avatar
Riffraff123
Thank you all for the help. I did get the new parts with the installation tool attached. I ended up placing the washers and spacer in the tank by hand as the tool never "clicked" in and would leave o rings crooked. I had to seriously "manhandle" the line to get it to go straight into tank. Seems like factory bend at end is too sharp. And I did try placing parts on the line and putting them in with it, but I couldn't get it to seat that way.
Old Sep 21, 2020 | 08:52 PM
Riffraff123
In case anyone ever has this issue and gets this far into this thread...
I've had to take the oil tank out 3 times now total to get my leak fixed. The trick is undoing the lines with tank slightly loosened as it gives enough room to pull the lines out, but not so much as it gets sloppy and moves all over.
The trick to putting them back is to have the oil tank in place but completely free and able to tip front to back to enable the lines to go perpendicular into the tank. When installing do vent (inside) line 1st.
showin4fun
Engine Mechanical Topics
Apr 22, 2020 02:55 PM
cmueller
Oil Archive (no new posts)
Mar 15, 2012 07:42 AM
kkiley
Sep 12, 2011 10:09 AM
Bonaro
Sep 6, 2011 01:54 PM
lowglide88
EVO
Apr 23, 2009 08:21 AM
