Rushmore 103 build options
Old Aug 10, 2020 | 01:08 PM
twincam10353's Avatar
twincam10353
Default Rushmore 103 build options
I have made a few posts in this section and you guys always provide excellent information and quality feedback. I originally made a post about upgrading my 16 FLHXS with a 110" big-bore kit, and it seemed that the general consensus was boring the original cylinders to 107" is a far better option (cost and reliability wise). Now I guess I am on the fence between these two possible paths: Keep in mind that I am planning on turning the wrenches myself over the winter.
Option A - Only cam chest work (cams, cam plate, bearings, oil pump). Material wise, let's call this route roughly $1,100.
Option B - The above work PLUS boring cylinders to 107", sending cylinder heads out for work as well, bigger throttle body & fuel injectors. Obviously this option will require some clutch upgrades as well (suggestions would be excellent). Let's call option B, an additional $2,500 minimum.
Right now my Street Glide has about 15,000 miles on it and I have not opened up the cam chest to measure crankshaft run-out (yet). This is my primary bike that goes on many weekend trips (500 miles about) so I really don't want to compromise much if any reliability. How much more performance would I gain by going all out as in option B aka is it really worth the coin? The only reason that I don't want to start with option A and then finish in the future with option B is because of cam-selection. I want the cam selected to meet the end result of the build, I don't want to change the cam twice. I am running Thundermax so I would plan on sending the jugs and heads to Zippers...
Thanks very much
Old Aug 10, 2020 | 02:42 PM
ntraindavefl's Avatar
ntraindavefl
Always do bigger better option if reliability can still be maintained. Zippers can fulfill that
Old Aug 10, 2020 | 05:28 PM
djl's Avatar
djl
Option B but don't think the cost/benefit is there for larger T/B and injectors for an additional 3 cubic inches; the OEM T/B and injectors should be adequate. You did not mention exhaust and depending on current setup, upgrading the exhaust system could be a better place to spend the money as well as replacing the air intake with the SE Heavy Breather. JMHO.
Old Aug 10, 2020 | 05:48 PM
Mattbastard's Avatar
Mattbastard
Why does option A require the pump and plate? For that matter, neither option requires it IMO. It's not like you're going with a 124" or anything.
I would do a solid 107" with pistons, compression ratio, and cams commensurate to your riding style. There's a few builders on this forum who can accommodate you there.
Old Aug 10, 2020 | 06:00 PM
ntraindavefl
It depends on the cam choice. If a torque cam build sure, OEM 50mm will tap out around 115/117 hp. If the build goals are 120+ then a $350 SE unit w $160 5.3s would make a difference in upper rpms. The stock TB will be the choke point on a build w head work
Old Aug 11, 2020 | 09:29 AM
twincam10353
I am currently running Thundermax, SE Ventilator Extreme A/C, and Bassani RR3 2:1.
I figured for the additional $600 why not while I am in there???
I guess I will need to leave this decision with Zippers (throttle body & injectors). I will have to get them on the phone and see what they suggest.
Old Aug 11, 2020 | 04:34 PM
djl's Avatar
djl
I don't disagree; dealers choice. My post was JMHO on cost/benefit for the gain.
Old Aug 11, 2020 | 04:38 PM
djl's Avatar
djl
I like Bassani; running the Prostreets 2:2 on my 98" FXSTD 115/115; a bit on the loud side but they work.
Old Aug 11, 2020 | 04:48 PM
Sparky357's Avatar
Sparky357
I would look into Revolution Performance 113 ci kit,their cylinders are pretty impressive.
Old Aug 11, 2020 | 04:51 PM
Steve Helton 2's Avatar
Steve Helton 2
113 kit won't fit a 103.
