Dyna good to bad
Old Aug 15, 2020 | 04:00 PM
ntraindavefl's Avatar
ntraindavefl
Default Dyna good to bad
Ok guys I’m head scratching. ‘11 dyna runs great for 10-15 minutes on multiple rides then like a switch gets a rough deep exhaust note with a little loss of power but still rides wout hesitating or misfires. It’s like the fuel and or timing just goes wacky. Comp test was normal each cylinder tested warm, plugs seemed darkish not too bad so swapped out but no change. Map sensor? Any good ideas? Running great then not each test ride same outcome. Heat is causing something to change
Old Aug 15, 2020 | 04:30 PM
Camarosx2's Avatar
Camarosx2
My first thought is eitms kicking on, does it only do it at idle? Is this a new bike to you?
Old Aug 15, 2020 | 04:41 PM
marcodarq's Avatar
marcodarq
if it was me,,,,id set up my fuel pressure gauge on it and go for a ride and see if the fuel pressure changes in relation to the symptom. that i'd do first to confirm it and get it out of the way. i'm assuming that you've got no codes as you didn't say so.
if you have a TTS or a PV you can make a data run on your test ride and review that info and see if it sheds any light anywhere.
m
Old Aug 15, 2020 | 04:58 PM
ntraindavefl
Owned bike since new. Symptoms are not idle related, a running condition
Old Aug 15, 2020 | 05:08 PM
ntraindavefl
m
Ya thought of fuel pressure but not sure why heat would affect it, like mentioned bike runs good for first 15 min. TTS module is the older black one, I’ve run flight recording on the newer blue ones but currently don’t have the hook up cables the dyna requires. Appreciate the input
Old Aug 15, 2020 | 05:30 PM
60Gunner's Avatar
60Gunner
Crank position sensor? Could be any number of sensors really.
Old Aug 15, 2020 | 06:42 PM
Max Headflow's Avatar
Max Headflow
Generally the cranks sensor will cause the bike to quit or be hard to start when hot.
The map sensor can be failing in a manner that causes it to run the slow part of the curve. I've had this issue on a carbed bike. Could be a temp sensors. Data recording will find that.
You could be loosing fuel pressure bit the bike will typically cough a lot.
Another issue could be sumping. It feels like the bike is running with the rear brake on. Compression braking works extra well.
Old Aug 15, 2020 | 07:36 PM
ntraindavefl
I know it’s not sumping, no brake like feel just a strong difference in exhaust note and minimal power loss. Map sensor going would increase hot? Don’t know, map going could retard or advance timing and alter AFRs, seems like it’s running like that and maybe reason plugs looked slightly dark. Only ran it few times w these symptoms just handful of miles. Same result each run like clockwork 10-15 min in. Not cutting out or hesitation just bogged down like the tune all of sudden sucks. I’ll have to start w the MAP but still curious why heat brings this on
Old Aug 15, 2020 | 08:06 PM
Max Headflow
I suspect that heat causes the MAP sensor to fail. In my case it drove me crazy. I had a higher compression 116 dyna. While it would feel a little sluggish, the big thing was that it wouldn't idle. Set the idle moderately warm and after getting it good and hot the idle would drop. Since it was carbed, it would almost die. Adjust the idle and next start up, idle too high. I replaced the intake manifold seals 3-4 times. Finally replaced the MAP and all was good.
Now you might be thinking. WTF does this have to do with my bike? Well, a 2011 is EFI and it knows how it adjust the idle automagicly. The big thing you will feel is a drop off in throttle response on EFI. If you do a log run, you should see the IAC steps go up.. A good way to place a marker in the data is to blip the throttle 3 times also remember your route when collecting data.. Look at throttle steps at idle. Also look at the intake and cylinder head temps.
Old Aug 15, 2020 | 08:46 PM
ntraindavefl
Diagnosing can be tough I’ve had my share of wrong guesses. Trying in my old age to slow down and think, ask smarter people for help. Yes EFI will take idle issue away, there is loss of power and with and exhaust note change really leads me to timing and fuel changes and I guess heat ruins everything and the sensor takes little time to crap out each ride.
Ive chased timing issues before w TTS on different bike and ya I used the 3 rev technique to mark, route awareness is good idea too.
