Evo Engine Rebuild
Old Sep 5, 2020 | 10:09 AM
GLevasseur's Avatar
GLevasseur
2nd Gear
Default Evo Engine Rebuild
Me and my dad are going to be rebuilding a 91 flht with the evo 80. He says the crank bearings are shot and it probably needs a new crank as well.
Just wondering how to go about diagnosis on that and choosing parts and whatnot
Old Sep 5, 2020 | 11:36 AM
Mattbastard's Avatar
Mattbastard
1. Get a Factory Service Manual
2. Call Darkhorse Crankworks
Old Sep 5, 2020 | 04:29 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How did you determine that the bearings are bad?
Evo flywheel assemblies aren`t throw away items, they are completely rebuildable.
You don`t need Darkhorse for an Evo flywheel assembly.
Old Sep 5, 2020 | 07:57 PM
Mattbastard
No, but they are damn good at rebuilding cranks.
Old Sep 6, 2020 | 07:15 AM
prodrag1320's Avatar
prodrag1320
any decent shop can rebuild EVO flywheels,we`ve been rebuilding everthing from knuckle to evo flywheels for 40 years,i see your from michigan,id contact IRON EAGLE in grand rapids
Old Sep 6, 2020 | 07:26 PM
GLevasseur's Avatar
GLevasseur
2nd Gear
Bike apparently has 400k on it its been making some bottom end noise for awhile according to my father who was the last rider on it. He says bearings are definitely shot and crank is hopefully rebuildable as of today. We haven't torn into the engine yet due to not enough time in our work schedules. I'll make plans with him to get into it and check it out if we have to ourselves. Also plan on contacting a few shops Tuesday when everything's opened back up on crank and bottom end rebuilding costs
Old Sep 7, 2020 | 06:24 AM
prodrag1320
4 hundred thousand miles???
Old Sep 7, 2020 | 06:45 AM
GLevasseur's Avatar
GLevasseur
2nd Gear
yep, apparently.
I said/asked the same thing
Old Sep 7, 2020 | 07:17 AM
98hotrodfatboy's Avatar
98hotrodfatboy
400k... Now that's worth bragging about.. Nice..
Old Sep 7, 2020 | 07:31 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Is that the original engine?
