2000 ultra cam install ?
Old Oct 23, 2020 | 09:43 AM
Snowfan's Avatar
Snowfan
Originally Posted by svarnster
S&S Install kit,part # 106-5896
S&S 4-Gear Set, part # 33-4275
Andrews Gear Drive Cams part # 288121G
these are the numbers listed in kit.
You probably already know this...It might be a good idea to check runout before buying parts. I'm new here and also planning gear drive on my 2000 95inch with 131K miles on her. Will check wobble first.
Old Oct 23, 2020 | 12:54 PM
svarnster's Avatar
svarnster
A friend has the run out tool. Trying to get all the ducks lined up before stripping her down. Hopefully only down for a week or so.
Old Oct 26, 2020 | 12:13 AM
svarnster's Avatar
svarnster
The cam gear set from S&S will work with the mm fuel injection. per S&S , The gear is raised to make the cam sensor work.
miafcowboy
Jul 21, 2020 10:16 AM
Puglia10
Nov 10, 2012 01:12 PM
OrdieSeniorChief
Nov 20, 2011 08:35 PM
mehurr
Jan 7, 2011 07:21 AM
garye5007
May 4, 2009 09:56 AM
