Lifters 99 TC 88
Old Oct 21, 2020 | 06:45 AM
Curly61's Avatar
Curly61
Default Lifters 99 TC 88
I have a 99 electra glide classic EFI 57.000 miles. I installed the Fueling HE+ cam chest kit with Andrews 26N Cams and Fueling He+ lifters, Cobra FI2000 tuner , V&H true duals and V&H slash cut slip on and Timken Inner Cam Bearings. My Problem is the lifters slid smoothly out from the top when I tore down the motor but when I went to install the lifter the front exhaust lifter goes about halfway and stops on both cylinders. Any ideas or suggestions am I missing something ?
Old Oct 21, 2020 | 06:52 AM
prodrag1320's Avatar
prodrag1320
are you sure its not just bottoming on the cam?
Old Oct 21, 2020 | 07:08 AM
Curly61's Avatar
Curly61
Yes I used a 6inch scale to measure the amount the lifter protrudes from the bore and cycled the engine lifter does not move, I have inspected the bore very clean no scratches burrs or gouges I must be getting the lifter cocked while installing or something as it came out very smooth.
Old Oct 21, 2020 | 07:22 PM
Max Headflow's Avatar
Max Headflow
You used the wrong screw length on the cam plate.
Old Oct 22, 2020 | 04:26 AM
Campy Roadie's Avatar
Campy Roadie
He makes a very good point. Check the bores for dents.
Old Oct 22, 2020 | 05:30 AM
Curly61's Avatar
Curly61
I will check this when I get home today, The new cam plate did not come with new screws I reused those I will cut some off and reinstall.
Old Oct 22, 2020 | 06:53 AM
Max Headflow
The problem is typically getting the cover screws and cam plate screws mixed. Cam cover are 1 1/4" long while the cam plates are 1". This has happened more than once.
Old Oct 22, 2020 | 10:47 AM
eighteight's Avatar
eighteight
That sounds bad, what is the remedy ?
Old Oct 22, 2020 | 08:45 PM
Ed Ramberger's Avatar
Ed Ramberger
WINNER WINNER CHICKEN DINNER - THE CASE IS DIMPLED. Mixed up cam cover and cam plate screws.
Old Oct 22, 2020 | 08:51 PM
Ed Ramberger
New cases unless a really good machinist can sleeve it and it's not too damaged to do that.
