Problem getting Pushrods back in
Old Nov 2, 2020 | 01:44 PM
Clammy's Avatar
Clammy
Originally Posted by mikeo33y
I am putting them into the head bores first and i am at top dead center on rear cylinder but i wouldnt think top dead center would make a difference to just get the push rods in place but only for adjustment
With the piston at TDC on the Comp stroke, the cam lobes will be on their base circle, so the lifters will be at their lowest point. Do one cylinder at a time, get the piston to TDC on the compression stroke, and try inserting the pushrods into the lifter bores first. That should work.
Edited to add: you need to have the piston at TDC on the comp stroke to adjust the pushrods and set the preload anyway, so you may as well get it all done at the same time.
Cheers!
Old Nov 2, 2020 | 08:53 PM
memphisharley's Avatar
memphisharley
if all else fails remove the lifter blocks..install the collapsed pushrods and lifter blocks at the same time. installing the pushrods in the heads then lifters.
Old Nov 4, 2020 | 02:43 PM
djl's Avatar
djl
See my previous #2. Not sure what pushrods the OP has but if the pushrods won't clear the lifter blocks with the base attached, sounds like he has those shown in the attached instructions. See page 2, paragraph 6. Maybe follow the instructions?
File Type: pdf
File Type: pdf
Rdcris
Engine Mechanical Topics
May 17, 2019 01:44 PM
470004
Feb 25, 2019 06:08 PM
foxman
May 10, 2013 10:44 AM
BatOuttaHell
Jan 17, 2013 11:33 PM
hd_rolling
Feb 3, 2012 11:28 PM
