Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
My son brought me a winter project -- an old hardtail that's been rode hard and put up wet. I get to strip off the ugly and install some cool. I needed something to do since race season was canceled.
I had the same conversation with my head porter who to say who dyno is right and who's is wrong its Alot BS around.
At the end of the day whatever it dyno at Im not doing anything else to it.
You have a good combo though its gonna be a ripper.
Making progress
Love the springer, gives it better lines than a long raked chopper look .
Not much of a build really.. Just bolting on some parts to a 2013 103" Streeet Bob.. Hillside stage II heads, Woods 5-6 cam, Zero deck the cylinders, rings, Port match throttle body, Supertrapp. SE clutch spring and a good tuner.. Not sure on the Air Cleaner yet.. Any recommendations? I Would be very please to see the torque in the >120 range..
-s and s 128 kit
-mow compensator
-s and s oil pump and cam plate
-gear drive cam
-t man 4059 cam
-610 lift s and s roller rockers
-heads by precision machine
-barnett scorpion clutch and billet basket
-dark horse crank balanced
-hpi 62 mm throttle body
-t man custom breather
-t man oil pan vent line kit
-power vision tuner
-hpi ss 2 into 1 exhaust
