Whats your Winter Build
Old Nov 15, 2020 | 08:14 PM
Bap227's Avatar
Bap227
Default Whats your Winter Build
Mines Is
110 Heads Worked by Mega-Flo
DarkHorse MOW Crank
Diamond Dome Pistons
662-2 Ps
S&S Cylinders
HPI 58-62 Throttle Body
HPI V2 air Cleaner
Pro Clutch
S&S PISTON OILERS
Boarzilla
AND I am thinking about getting the 34 Darkhorse compensator.
2021 should be fun
Old Nov 16, 2020 | 07:38 PM
kblhd's Avatar
kblhd
Fuel Moto 110 kit
S&S Dark Horse Blueprinted Balanced crank
Fuel Moto Level B heads
S&S cam plate and oil pump
Woods TW -777 cams
SE forged rocker plates
Rocker Lockers
Fueling head studs
PV tuner or FP3 (have both)
S&S power tune duals
V&H 4” Monster Rounds
SE Ventilator A/C
Scheduled for first of December
Old Nov 17, 2020 | 08:24 PM
Zedbra's Avatar
Zedbra
Rebuilding my transmission with Baker goods
Pulling my jugs to inspect my 110" kit, will know more when I get into it.
Old Nov 18, 2020 | 10:58 AM
470004's Avatar
470004
Camshaft change with updated oil pump.
Old Nov 18, 2020 | 11:15 AM
Bap227's Avatar
Bap227
What oil pump you running
Old Nov 18, 2020 | 11:34 AM
twincam10353's Avatar
twincam10353
More info on this?
Old Nov 18, 2020 | 01:21 PM
kblhd's Avatar
kblhd
Originally Posted by twincam10353
More info on this?
Sent in a brand new S&S Timken crank to Dark Horse to be balanced for the new 110 pistons and welded. They disassembled, balanced, reassemble, pro plugged and welded.
Old Nov 18, 2020 | 01:24 PM
twincam10353
Wow, is that necessary on an S&S crank? On the other hand, why not just purchase a Darkhorse crank? How much did that cost...
Old Nov 18, 2020 | 04:56 PM
kblhd's Avatar
kblhd
$738 including freight. I already had the crank which I got a good deal on. Indy doing work suggested that I get it welded. Figured at this point might as well have it welded and blueprinted to my exact build. Dark Horse crank would have been around the same overall cost. Money at this point is moot point. I will have roughly 38000 total invested in a bike that at best is worth 15000 why stop now?
Old Nov 19, 2020 | 07:36 AM
Big_O's Avatar
Big_O
Mine has been down since October '19 LOL. Finally on the dyno.
Mutant Motors 110 Heads
HPI 62mm throttle body
HPI V2 A/C
Custom CP Pistons 12:1 Compression
S&S Cylinders
TW-68G Cams
Darkhorse Man-O-War 4-5/8" Crank Pro Edged and Windowed
1 7/8"-2"-2 1/8"-2 1/4" Exhaust by Mutant Motors
Wood Billet Rocker Plates
S&S Roller Rockers
Fueling/ARP Head Studs and Bolts
S&S Cam Plate and Oil Pump
Dual 10 Row Jagg Oil Coolers
Pure Power Oil Filter
Evo Industries 30t Comp Eliminator
Bandit Clutch
Trask Billet Basket
Zippers Chain Drive
PowerVision
