Cam upgrade – Need for bearings?
Old May 23, 2021 | 11:34 PM
Sandwiz's Avatar
Sandwiz
NO, and I never used the word "bummed"
Old May 24, 2021 | 05:52 AM
prodrag1320's Avatar
prodrag1320
Bearings should be replaced at mile 1,no need for the pump & plate, nothing's wrong with the OEM parts
Old May 24, 2021 | 05:55 AM
Notgrownup's Avatar
Notgrownup
It’s so easy to replace. Cheap insurance.
Old May 24, 2021 | 08:49 AM
Screamin beagle's Avatar
Screamin beagle
Should do the cam plate and oil pump along with the bearings while you're in there. S&S makes a real nice kit that has everything you need in it.
Originally Posted by Sandwiz
yep doing the S&S cam plate and oil pump already, and I have the Super tuner pro but I think it will be useless for the TW-222 cams SO looks like a Power Vision is also in the works, what a money pit!
Originally Posted by PureHybrid
You spent the money on the S&S hardware but are bummed because these guys told you to spend $20 on bearings?
lol...exactly what I was thinking...blew 650 bucks on replacing parts that are more than adequate but can't get past 20 dollars for a known weak part? Come on man lol.
Old May 24, 2021 | 10:20 AM
djl's Avatar
djl
It's easy to spend other people's money. As has been said, no need to replace the cam plate and pump; more than adequate for the application. If the parts have not been installed, return them and spend the money on the Powervision and tune.
Old May 24, 2021 | 10:54 AM
koolbreez's Avatar
koolbreez
just put a set of Woods tw-222 in my 2015 Fatboy Lo check out the power and torque gains I posted in Dyno room bike runs fantastic now
Old May 24, 2021 | 12:06 PM
eighteight's Avatar
eighteight
No but you did say "money pit"
Old May 24, 2021 | 03:04 PM
60Gunner's Avatar
60Gunner
Why? Because it looks purtty? Always someone throwing this waste of $$$ advice out there in a cam thread. Lotta $$$ to **** away needlessly that could be spent on something worthwhile.
Bearings are dirt cheap and easy to do. It's a no brainer.
I tuned S&S cams just fine with the SE Pro Super Tuner, btw. But if you're looking to replace it, I'd go with the TTS Mastertune. The PV might be easier to use for many here, doesn't make it better tho. Most confuse FM's base map support for it with it being a better tuner. Base map support from a third party or vendor isn't necessary with the TTS. It is for the PV. Just my
If you can find a tuner with a dyno that tunes with the SE Pro Super Tuner, it's more than capable. Maybe a little trickier on your own tho because of base maps only being available for SE cams and other harware.
But keep in mind, these are only base calibrations no matter what tuner. Including the ones you get from FM for the PV. They're not a finished tune. That requires a dyno or smart tuning/v-tuning whatever the term for each tuner done on your own for YOUR bike.
Old May 25, 2021 | 07:36 AM
JoeeJoee's Avatar
JoeeJoee
Had TTS on a couple bikes in past, most excellent tuner.
Used PV on last two also excellent, but I like the RPM & MPH on PV up on the bars for easy glance.
Old May 25, 2021 | 08:24 PM
Since 1968's Avatar
Since 1968
On changing cam bearings, usually your new cams have higher lift than stock, putting more pressure on the stock bearings. An upgrade will pay itself back many times over. As mentioned above, you should be able to rent a blind hole bearing puller from Autozone or others, so no great added expense.
