Valvetrain Noise
I can tell you that others before you have started similar threads, knowing for sure that the pushrods were adjusted properly only to learn that they weren't.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
Also on amazon.com...
Did you use red loctite? Some do.
Another thing to check with gear driven cams in the early models is the clearance between the rear cam gear and the fastener boss just above the 9:00 position facing the cam cover. Although not a common occurrence, depending on factory clearances, there could be contact between the rear cam gear and the boss. Clearance should be .030" to allow for expansion growth. I doubt that this is an issue but being an **** SOB, check the boss for contact witness marks.
Loose gears will make a "klacking" noise and tight gears will "whine", the clearances are not very forgiving so out too much one way or another can cause noise and possibly damage. I don't know if this is a contributing factor but certainly a place to start and eliminate as a factor. If the gears were too tight, something could have happened like loosing a gear tooth in the first 1000 miles causing the noise to present recently.
At 24TPI, preload should be set at 3 to 4.5 turns. I would readjust for more pre-load but don't believe pre-load would cause the "knock" you describe while turning the motor through. You shouldn't hear anything while turning the motor through as you describe. Remove the cam cover and the rocker box covers and have a buddy watch both while you turn the motor over. If making a noise when turning the motor through, as you describe, the source of the "knock" might be obvious.
I would not be riding the bike until I had this figured out.
https://www.youtube.com/watch?v=9N2pf70z0fA
https://www.manualsdir.com/manuals/571654/ss-cycle-gear-drive-cams-for-harley-davidson-twin-cam-88-engines.html?page=6
