Post cam install question
Also, EITMS is primarily for the passengers benefit in reducing heat. "The Engine Idle Temperature Management System (EITMS) can provide limited cooling of the rear cylinder for riders who frequently find themselves in prolonged idle conditions or traffic congestion. Riders can enable or disable EITMS to complement their riding style."
EITMS will turn off the rear cylinder fuel injector when all of the following preset parameters are met:
- Throttle position is at idle
- Motorcycle speed is under 1.2 mph (2 km/h)
- Engine speed is under 1200 RPM
- Engine Temperature (ET) sensor input reading is above preset level
- Ambient Air Temperature (AAT) sensor reading is above preset level (radio equipped models only)
thank you for the input.
They adjusted the parameters of the eitms so it enables later. (Not a fix, just activates 10 degrees later)
As said before the bike runs really well for the upgrades it has. It got 86hp 101tq which is in-line with its upgrades.
The tuner is well known and trusted and I have to give them the benefit of the doubt.
my only real concern was the eitms enabled more frequently than before the tune.
having said that the one thing I did different was prior to the cam swap I changed to Lucas “Dino” oil. (Didn’t want to run synthetic post upgrade of cams,lifters,bearings etc.)
Not sure but could it be possible that the Dino oil contributed to my heat issue?? Always used synthetic prior.
Changing back to synthetic soon so will see.
Not too worried.
Heres the tables if anyone with knowledge wants to comment. (Just numbers to me)
Initial tune rear
Initial tune front
Retune rear
Retune front
