ticking at start up from 1900 to 2300 rpm
Old Sep 6, 2021 | 12:12 PM
djl's Avatar
djl
Originally Posted by holmsea
I cant answer that question -- I may be able to find out tho - I personally think its a lifter or a push rod --I am no engine guru but it seems like one of the two ! I thought about the rocker lockers but the noise is only at start cold in that specific rpm-- Is there a way to find out first before I spend another grand on it -- this is why Im asking questions on here first-- I appreciate all info from everyone -- I know its not easy to determine without hearing bike but Im sure enough guys on here have had there fair share of time working on harleys
No need to spend a grand. IIRC, your tech adjusted push rods? I am bettng he set preload at .100" or thereabouts, so increasing preload might help and would be the first thing to try. If that doesn't help, my money is on a bad lifter. Rocker Lockers are cheap; can't hurt, easy DIY project and eliminates the rocker shaft movement as a source of the noise.
Old Sep 6, 2021 | 02:40 PM
holmsea's Avatar
holmsea
Do the rocker arm shafts make noise at any rpm on start up or a specific rpm -- I dont believe thats the case since its a very specific rpm ---
Old Sep 6, 2021 | 02:59 PM
holmsea's Avatar
holmsea
Thanks all -- I will be having the pushrods readjusted to start and see where that gets me !! I will post all work done --
Old Sep 12, 2021 | 12:46 PM
holmsea's Avatar
holmsea
Update --- had the pushrods readjusted plus he said he gave them one extra flat turn--- picked up bike and it didnt make ant ticking noise at all---started bike the next morning , nothing -- after work, nothing and for about the next 5 or 6 starts just like it is suppose to sound , no ticking thru the 1900 to 2300 rpm!!!
Yesterday I rode for about two hours had lunch and after an hour started up bike and it started ticking again at idle thru the rpm range for about 5 - 6 minutes then gone- rode two hours home !!
started bike today and now I have the ticking back at start up from 1900 - 2300 rpm again then stopped after about 4-5 minutes--- does it sound like lifters ??
Old Sep 12, 2021 | 02:19 PM
gdishman's Avatar
gdishman
How many turns did your guy adjust them to? plus 1 flat Still sounds like you still need them turned 2 more flats.
Old Sep 12, 2021 | 02:23 PM
holmsea's Avatar
holmsea
I will ask him tomorrow ! Do you think it can still be pushrods after the 2 hour ride and then re start with ticking at all rpms ?? Im no pro just really confused and so are both the guys that work on my bike!
Old Sep 13, 2021 | 05:22 AM
gdishman's Avatar
gdishman
Yes Just give them a half of turn.
Old Sep 13, 2021 | 11:54 AM
djl's Avatar
djl
Yesterday I rode for about two hours had lunch and after an hour started up bike and it started ticking again at idle thru the rpm range for about 5 - 6 minutes then gone- rode two hours home !! started bike today and now I have the ticking back at start up from 1900 - 2300 rpm again then stopped after about 4-5 minutes--- does it sound like lifters ??
Short answer is yes. You could turn another flat but the results would probably be the same. The lifters are bleeding down but then pumping up again. You could probably eliminate any ticking with a set of Johnson Hy-Lifts from WFO Larry but if the ticking stops as the motor warms up, why bother?
Old Sep 13, 2021 | 12:11 PM
porkster's Avatar
porkster
Well I’ll tell you what solved the ticking in my twin cam, the Axtell Twin Cam bypass valve. Quieted it right down.
Old Sep 13, 2021 | 02:21 PM
Max Headflow's Avatar
Max Headflow
If the lifters are SnS premiums, I'd run them for a while. They'll get better. My theory is that they are slow bleed lifters and when cold there is so much drag on the plugger, that they don't recover until the oil gets hot. The Woods premiums are the same way. You can try increasing the oil pressure buy adding a stuffer spring to the relief valve, a spacer, or even the Axtel valve. It might help. Seating deeper also helps mainly because the plunger can only collapse so far. Don't know what the temps are in Ontario right now but you might want to try lighter oil.
