Spring chain tensioner
Old Sep 27, 2021 | 04:07 AM
ferokulda's Avatar
ferokulda
Default Spring chain tensioner
Hello.
Are these spring chain tensioners for TwinCam 88 better than the current original H-D? Is the plastic shoes CYCO?
https://americanclassicmotors.com/pr...arley-twin-cam
Thanks.
Old Sep 27, 2021 | 04:15 AM
Hoginedgewood's Avatar
Hoginedgewood
Originally Posted by ferokulda
Hello.
Thanks.
I have seen the plastic sold individually. I was changing the whole pieces every 25 -30k, but could have gone longer. Made 100,000 k and sold the bike.
Old Sep 27, 2021 | 12:50 PM
djl's Avatar
djl
Hello.
Thanks.
Those are Twin Power replacements but not sure if they are CYCO shoes re-branded. CYCO does sell to others and allow re-branding but not sure if the sell to Twin Power. I would not buy unless those replacments can be confirmed as CYCOs.
These have been confirmed as CYCOs.
https://twincamtensioner.com/
Old Sep 27, 2021 | 02:11 PM
ferokulda's Avatar
ferokulda
From https://twincamtensioner.com/product...tensioner-kit/ are out of stock. I'm looking for whole chain tensioners, not just shoes. Are the new original H-D tensioners (material shoe - delrin) better than before? I can use them without fear?
Old Sep 27, 2021 | 06:16 PM
djl's Avatar
djl
IIRC, Delrin is the same material as the early OEM tensioners. Have you called CYCO? In the past they did not sell retail, only to shops but give them a call. They may be able to sell direct to you or refer you a source. Maybe the can confirm if the Twin Power shoes are CYCOs. I have to believe there is a source; just have to keep looking. Worst case, you mihgt have to buy the shoes and the install tool and DIY them; videos show how.
Old Sep 27, 2021 | 10:40 PM
ChetB's Avatar
ChetB
http://Cycogasket.com This is Cyco's website. I believe they have a minimum order amount,but try emailing them or give them a call. Thr stuff you are interested in is listed under "new parts" in the menu.
Old Sep 29, 2021 | 09:20 AM
ferokulda's Avatar
ferokulda
Friends.
Is it also advisable to replace the stock oil pump with a better one, for example Feuling OE+?
https://www.feulingparts.com/sku/7010
Thanks.
Old Sep 29, 2021 | 12:05 PM
djl's Avatar
djl
Friends. Is it also advisable to replace the stock oil pump with a better one, for example Feuling OE+?
Thanks.
Not necessary. The OEM cam plate and oil pump are quite adequate.
Old Sep 30, 2021 | 02:46 PM
ferokulda's Avatar
ferokulda
So, I have H-D FXST (Softail Standard) year 2003, TwinCam 88, only with 12 000 miles.
Which parts I will replace with new ones:
- inner cam bearings
- spring chain tensioners
Which parts I will leave original:
- cam plate
- chains
- cams
- oil pump
- pushrod (disassemble via rocker box)
It is advisable to replace these parts with new ones as well?
- outer cam bearings
- lifters (for example S&S)
Do you agree with everything?
Old Sep 30, 2021 | 03:29 PM
djl's Avatar
djl
- inner cam bearings OEM probably OK if not replacing cams but replacment is cheap and an upgrade. Probaby a gazillion HDs running OEM with no issues.
- spring chain tensioners Yes, CYCO.
- cam plate Yes
- chains Yes
- cams up to you but it would be a good time to add a set of "bolt in" cams, like Andrews 26 or S&S 509 or even the SE204
- oil pump Yes
- pushrod (disassemble via rocker box) Yes
- outer cam bearings yes if replacing cams
- lifters (for example S&S) at 12K miles, "B" lifter should be OK but if you want to change; Johnson Hy-Lif from WFO Larry (Larry's Machine)
See replies above. Is the bike carbed or EFI?
