q-tip fell of in engine
Old Oct 14, 2021 | 04:00 PM
t150vej's Avatar
t150vej
Please don't think this a dumb question but - which stud hole did it fall into? And have you rotated the engine at all since?
Old Oct 14, 2021 | 04:41 PM
kevvan's Avatar
kevvan
in the rear left, front cylinder stud hole, yes i have rotated the engine by hand when i tried to get it out.
Old Oct 14, 2021 | 04:55 PM
Screamin beagle's Avatar
Screamin beagle
Was it an official brand name q-tip or a generic knock off?
Old Oct 14, 2021 | 06:11 PM
t150vej's Avatar
t150vej
Was thinking about how to maybe scrape it off but since you've rotated, that's be an exercise in wasting time.
Since it was the cotton only, I wouldn't give it another thought. You wouldn't believe stuff I've found when splitting cases without ever being an issue. And you know there has to be tens of thousands of these things running around with chips and flakes of base gaskets and heaven knows what else been run thru them without any problem.
Old Oct 14, 2021 | 09:16 PM
hvacgaspiping's Avatar
hvacgaspiping
im just scared that it will get stuck in a bearing or oil passages or something. Only idea i have now it to remove the engine from the fram and fill it with oil and hold it upside down so that mf comes out. At the same time it feels like in over thinking this..
You`re overthinking this...... A lot worse things get into the engine and lower end and do nothing to it. I wouldn`t worry about it.
Old Oct 15, 2021 | 11:19 AM
hardheaded's Avatar
hardheaded
I would take a piece of fuel line and tape it inside of my shop vac. hose and then stick it down into the bottom of the case and suck everything up i can. Make sure the vacuum is clean so you can see what you have pulled out. 3/8 hose would be good to start with and then move down to 1/4 inch. Keep going after it until you get it.
I would be worried it would find it's way into a oil passage and starve something for oil. Or it could even break the keyway in the oil pump. Kinda depends on how big the piece is.
Old Oct 15, 2021 | 04:34 PM
roussfam's Avatar
roussfam
Great idea
Old Oct 15, 2021 | 06:23 PM
kevvan's Avatar
kevvan
i have already done that without succsess i think i will just forget it put everything together
Old Oct 15, 2021 | 06:34 PM
kel03's Avatar
kel03
This is an eery dilemma ! Looks like you've exhausted trying, not sure this will even be an issue.
RhynoRocK
EVO
86
Sep 21, 2021 07:53 PM
stephtell
EVO
Oct 8, 2016 05:23 AM
trnewman
May 11, 2013 04:30 PM
Jefferson
Exhaust System Topics
Nov 20, 2009 07:19 PM
DonM
Jul 4, 2009 11:07 PM
