q-tip fell of in engine
Old Oct 12, 2021 | 06:22 PM
kevvan's Avatar
kevvan
Default q-tip fell of in engine
hello!
i was cleaning the threads for the cylinder studs with a q-tip, and the cotton from to q-tip fell of in the threads. tried to get it up but pushed it down instead. i think the hole leads to inside the crankcase. Does anyone have any idea of how i can get it up? it was the rear left hole for the front cylinder stud.
it is a 1998 evo
Old Oct 12, 2021 | 06:39 PM
Yankee Dog's Avatar
Yankee Dog
Maybe you got lucky and it fell onto the flywheel and is stuck on the flywheel. Any way to get a flashlight and maybe a small dental type mirror and start looking around. I would not rotate the crank without looking around in there first.
Old Oct 12, 2021 | 06:56 PM
brakeless's Avatar
brakeless
Donnie thinks vacuum, and a straw.... use the old lady's nylon in the vacuum hose to see what you catch. https://youtu.be/6ABBE39iHY0
Old Oct 12, 2021 | 07:05 PM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by brakeless
Donny thinks vaccuum and a straw....
Where's a good good coke ***** when you need one
Old Oct 12, 2021 | 09:16 PM
Since 1968's Avatar
Since 1968
Did it exit through the stud hole or is it still in the threaded passage? If it's in the passage you might be able to get it with a dental pick.
Old Oct 12, 2021 | 10:24 PM
brakeless's Avatar
brakeless
Problem with a coke ***** is she'd probably use the cotton to strain it in the spoon when she cooks it up to shoot it!
Old Oct 13, 2021 | 03:58 AM
kevvan's Avatar
kevvan
It did exit through the threads
Old Oct 13, 2021 | 04:00 PM
kevvan's Avatar
kevvan
Does i have to get it out? Or will the engine "eat" it up?
i cant get it out
Old Oct 13, 2021 | 06:23 PM
hvacgaspiping's Avatar
hvacgaspiping
i cant get it out
If all it is is a small piece of cotton, just make sure it got through the small passage. Shove it the rest of the way through the passage to a larger area. Oil flow, gears and movement will eventually move it to the oil filter, and you`ll be okay.......... If you`re somehow mistaken about it dropping into a small hole, and it simply dropped onto the piston, it will just burn up along with the fuel mixture when the engine fires up.
Old Oct 14, 2021 | 06:45 AM
kevvan's Avatar
kevvan
im just scared that it will get stuck in a bearing or oil passages or something. Only idea i have now it to remove the engine from the fram and fill it with oil and hold it upside down so that mf comes out. At the same time it feels like in over thinking this..
