Cam Chain Tensioners?
Old Oct 20, 2021 | 04:31 PM
OLD 96's Avatar
OLD 96
Default Cam Chain Tensioners?
Probably been asked before. Doh. Can early cam chain tensioners be converted to late model hydraulic tensioners? I think hydraulic tensioners were introduced in 2007. Or do you have to change the cam plate on the earlier models.? Thanks.
Old Oct 21, 2021 | 04:52 PM
dawg's Avatar
dawg
You can convert the 99-06 spring tensioners to hydraulic with a kit. You have to change the plate and use conversion cams. You can’t just add the tensioners to the existing stock plate.
Old Oct 30, 2021 | 07:05 AM
csonni's Avatar
csonni
I'm slowly checking into the Screamin' Eagle upgrade kit but there is no mention of replacing the cams. It's an expensive upgrade. I've only got 15,000 miles on mine and have not yet checked the tensioners. I suppose you can just change the tensioners themselves but they're bound to go eventually as well.
Old Oct 30, 2021 | 12:43 PM
djl's Avatar
djl
Not necessarily. Replace the OEM tensioners with CYCOs which are lasting much longer with no reported issues of failure. Just check them every 25K miles or so.
Old Oct 30, 2021 | 03:16 PM
csonni's Avatar
csonni
I would much rather just replace the tensioners. I'll check into those. Thanks.
Old Oct 30, 2021 | 06:26 PM
djl's Avatar
djl
https://cycogasket.com/twin-cam.html?cat=37
https://twinpower-usa.com/cam-chain-...ner-shoes.html
Plenty of videos on the R/R process.
Old Oct 30, 2021 | 08:53 PM
Bat61's Avatar
Bat61
I went with the Feuling kit, it also upgrades the oil pump
Old Nov 8, 2021 | 03:54 PM
mn.roadking's Avatar
mn.roadking
I also went with the Fueling kit. It looks like a copy of the SE kit only you use your stock cams
Two Lane Tramp
2014-2024 Touring Models
19
Jan 24, 2018 08:59 AM
harley#1
Jun 8, 2014 06:38 PM
jorswift
Jan 22, 2010 08:30 AM
1peter
Jun 20, 2009 11:03 PM
Mr Wonderful
Jun 17, 2006 07:50 PM
