Metal in oil filter
Old Nov 6, 2021 | 07:10 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by blackjeep
Have the later 3mm oil ring pistons.
you are right, there is some noise cold until engine warms up.
once warm it sounds good.
i usually change oil between 2500 -3000 miles and the oil is never black. It gets dark but nowhere near car oil after 5000 miles.
Without the cleanable oil filter I wouldn’t even be thinking about this.
just that pinch of yuck making me sweat a bit.
don’t know if crank has shifted. No new vibrations and pressure is right where its been for life of the bike.
One way to tell if cranks is out of whack is the oil pump loosening up. See how long it takes for oil pressure to come up on a mechanical gauge. If it starts taking longer, the pump has started to loosen up.
Old Nov 7, 2021 | 05:43 AM
blackjeep's Avatar
blackjeep
Excellent advise. I’ll watch that closely. Ihave a mechanical guage mounted on my rocker box.
Needle is up almost instantly on start up. I’ll keep watching that.
Old Nov 8, 2021 | 06:02 AM
prodrag1320's Avatar
prodrag1320
id be tearing it down,obviously there is something wrong.why wait till a small (maybe) problem turns into a major problem.try draining the sump itself into a clean pan & see what you get
Old Nov 8, 2021 | 11:24 AM
blackjeep's Avatar
blackjeep
Not a bad idea Kirby.
i’ll drain the sump this weekend and see whats doing but salt is on the roads now so I’ll likely pull at least the cam chest down.
maybe I’ve just got a lifter flaking or cam loosing finish.
won’t be able to sleep at night if I don’t know…
Old Nov 13, 2021 | 08:33 AM
cj24's Avatar
cj24
Originally Posted by bustert
well, the filter comes with a warm and fuzzy green feeling, BUT,
these screens have been around for eons of time and are heavily used in the industrial world but they have a dark side, they accelerate wear. another feature is that as wear increases so does the need to service more. we had them and with monitoring systems, truth told, the factory filters out performed them but then again 70>90 bucks each and 7 to a pot. pay me now or pay me later. we wound up installing centrifuges if screens were used.
i will never use one that is for sure.
how do reusable oil filters accelerate wear?
Old Nov 14, 2021 | 01:43 PM
blackjeep's Avatar
blackjeep
Well. Got some time to tear things down.
the metal was in fact magnetic.
i found a very small amount in sump, I mean very very small amount. Not enough to even notice unless you have 10x magnifiers on and a really bright light.
I did find more of it in my rocker boxes ( more the front than the back. Again, not much but I’m looking very very closely.
I’ve pulled the whole camchest (pump, lifters…everything).
Absolutely no strange wear on anything except the pump rotors. They are within spec but very obviously had something go through (back rotor has a gouge that you can see and barely catch with fingernail.
strange thing is one of the chain tensioners (outer) is missing its internal spring. Don’t know how the hell that happened. Don’t see a way for it to escape into oil.
was expecting to see a lot of runout on crank.
well 0.001” in cases. Shocked. Absolutely shocked. I have ridden this thing hard so that makes me happy.
My working theory is this…
About 2500 miles ago I installed high ratio rockers (screaming eagle) the rub surfaces are broke in now but not excessive. I suspect the magnetic material I found in filter, rocker boxes and small amount in sump is wear/casting flash off of the new rockers.
shame on me for not cleaning them better before install.
unless I come up with a better theory I’m going to replace pump rotors and both tensioners.
clean clean clean and re-assemble and flush with several oil changes in a row ( like back to back to back idling in garage).
any thoughts?
Old Nov 14, 2021 | 02:34 PM
LenBoyLo's Avatar
LenBoyLo
any thoughts?
Sounds like a good approach to make a conclusion. Is there anywhere you can attach a magnet to have those magnetic particles glom to and stay in place ? I run with one on the underside of my oil tank (softail) just at the feed side low point. For just in case. I also run the cleanable mesh filter. But not seeing particles in either place.
Old Nov 14, 2021 | 06:18 PM
blackjeep's Avatar
blackjeep
Filter has a magnet as well as drain plug so I think I’m covered there.
Old Nov 24, 2021 | 12:59 PM
jake24lt's Avatar
jake24lt
you may want to flush your oil cooler as well. Some say its better to replace but the jury is out. Lifters seem to hold crap in them too.
Old Nov 24, 2021 | 01:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
A magnet on the outside of the oil tank?
So if the magnet falls off, or some clown pulls it off and sticks it back on, all the crap that was there will be released.
You don`t need a magnet if you have an oil filter.
