Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Why not ? If they bike is in gear and clutch in it should start. If it is a trike the brake must be applied. If it is not starting you likely have a bad switch Try this IN gear hold clutch and front brake try to start it.
Unless it is below 20 degrees I always start mine in gear. Once it is down to 20 the clutch drag can slow starting because as we know HD clutch does drag a bit.
