Primary fluid change 98superglide
Old Jun 20, 2021 | 08:14 PM
98glider's Avatar
98glider
Default Primary fluid change 98superglide
Hello I am the original owner of this 98 super glide. I just change the primary fluid and I only used about 18 ounces now I have about 45,000 miles on it and I’ve always change the fluids but this time I noticed it wasn’t as much that I used. I do have a manual and I know there’s a difference between years as to the height of the fluid upright. I drain the fluid. I took the bike for a ride seems like everything’s good should there be any concerns thanks
Old Jun 20, 2021 | 08:36 PM
daven9113's Avatar
daven9113
Do you drain the whole primary, and then fill it to the required amount by your book? Is there a primary leak? Do you know if your engine oil has increased. There are possibly three things that could have happened: 1) not filling primary to specified amount 2) leaking out of primary to ground 3) primary fluid getting into the engine through the engine sprocket seal.
Old Jun 21, 2021 | 04:21 PM
98glider's Avatar
98glider
I do not know how much was in there I changed all 3 fluids in one container. But when zi changed the primary I drained it waited for no more coming out. Put the screw back in filled to the clutch like the manual says and did take only about18 oz. which I thought was unusual
Old Jun 21, 2021 | 05:53 PM
daven9113's Avatar
daven9113
If what you have been doing is working for 45K miles, then I wouldn't change it. The oil is just splashing around to lubricate things. And if the level is reaching the bottom of your clutch pack, then you should be OK. In my bike, I just put 1Qt in, and be done with it. I would keep an eye on your engine oil level.
Old Jun 21, 2021 | 08:43 PM
98glider's Avatar
98glider
Ok thanks. Oil level been good engine that is. Will check after 100 miles. Thanks again
Professor
May 4, 2019 08:20 PM
FL-FLSTC
2014-2024 Touring Models
20
Feb 22, 2018 08:09 AM
lionsm13
Jul 8, 2012 12:16 PM
dawg
May 22, 2007 05:59 PM
06dynablack
Aug 13, 2006 11:14 AM
