Cam sprocket torque
Old Feb 20, 2022 | 01:40 PM
Big Dave's Avatar
Big Dave
Default Cam sprocket torque
Have FSM but can only find the crank sprocket torque of 24 ft lbs . This is for a 09 96 ultra
Is it the same for the larger cam sprocket ?
Thanks
Dave
Old Feb 20, 2022 | 02:54 PM
Big Dave's Avatar
Big Dave
Found it 35 lbs
Terminology problem on my end --- cam sprocket flange bolt----
Dave
Old Feb 21, 2022 | 09:37 AM
Gearhead88's Avatar
Gearhead88
These newer manuals are frustrating to those who are used to older manuals . The material and content is there , it's just laid out different , making us look harder to find the information we need.
I don't care for the format changes , it is no longer assembled in any logical sequence and you have to know the lingo as they see it , you must be familiar with the terminology as some keyboard desk jockey calls it .
M8 manuals no longer go into any detail at all about rebuilding cylinder heads , just replace them .
Old Feb 21, 2022 | 10:05 AM
Jackie Paper's Avatar
Jackie Paper
With it locked with blocktool, Tighten both 15 ft/lbs. Then loosen both one turn. (smooths threads) Then tighten cam 34 ft /lbs and crank one 24 ft/lbs
(that's out of the service manual)
Old Feb 21, 2022 | 10:22 AM
brakeless's Avatar
brakeless
And don't forget to apply oil to bolt flange and washer right?
Finsy
2018+ Softail Models
21
Jan 21, 2023 11:20 AM
supernac
Milwaukee Eight (M8)
May 26, 2021 04:58 PM
lhgdale
Jun 26, 2020 04:55 AM
OZARKTOAD
Sep 22, 2019 12:58 PM
shakerharley
Jan 23, 2012 08:32 AM
