96 to 103
Any heat issues would be tune related and 107s can be bored .10 over as well. That said when the first guy that bored mine did them out of round, I picked up another set of cylinders for $50.
Another 10 to 15 hp/torque, or more in my case with different cams etc. is a nice little bump that can definitely be felt on the butt dyno. I'm seeing mid to upper 120s with the right supporting hardware, good flowing heads, and a good tune.
Nothing wrong with 104hp and no reason not to keep the 570s. They're a good cam.
But even another 10hp/torque would be beneficial, especially riding 2up, and would quite likely even run cooler by the motor not having to work so hard to pull the weight of 2up riding. It can also improve fuel mileage for the same reason. I've seen more power do just that unless you can't control the right wrist of course.
As for crank work, if you're willing to risk it as is with a 103, no reason not to with a 107. And the timken bearing is an unnecessary waste of $$$ if/when you do address it that can actually hinder self alignment. Some builders even refuse to do it.
I see it as nothing but a feel good thing. Makes the customer feel good by having it and makes the builder feel good about his bottom dollar.
Throw an S&S crank in and be done. No welds to come loose either.
The shop said he will not bore cyliners on 96", crap bottom ends
Will need to decide what to do with my 96" soon has 70k. You could argue building anything after 02, is questionable.
He won't bore for 96" bikes cause bottom ends are junk. As in 2007+ bikes. A stroked 88". I am going to 95 from 98" on a 88". He will not bore any size for 96", a post 2007. I am not sure you should bore for any bike after 2002, myself. But he will do that
