Exhaust stud replacement
#1,,, I posted this over in the Exhaust forum, but I thought I would post it here for a faster response also.
#2,,,, what do you all think is the easiest way to remove a stud without breaking it?
#3,,,,, I have found several different types of replacement studs and nuts other than stock to replace with. The stock ones have lasted this long, however, in anyones opinion, are there better studs and nuts out there to use other than stock. Thanks .
after that, stock or S&S exhaust studs and Wurth copper anti sieze.
m
m
__________________Knowledge Is Power
