Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Assuming your S&S cylinders are 4.125 bore, you will still have to bore cases for the larger dia spigots to fit. If you want to go that route cut cylinders to 4.912 and use pistons with 1.083 comp height instead of the S&S pistons which are 1.050
Whole lot easier to keep 107, go with domed pistons. At 15k cylinders might clean up with light hone. Your machine shop will have to figure that out. Worst case you have to get new cylinders for 107
Save the 660ps2 for better heads with proper headwork
I’m probably jumping the gun here since I don’t want to tear it down yet. But y’all have given me a few new options to kick around when I do
I wondered If changing piston pin location was an option! Where would be a good source??
Only SnS uses the 1.050 piston CH.. I believe Wiseco, Keith Black (1.076), CP (carrillo), Screaming eagle and Mahl make 4 1/8 pistons with a somewhere between a 1.082 to 1.090 piston CH. Makes the piston CH the same as standard 4 3/8 stroke TC motor.
A really good person to talk to about this is WFOlarry. You can get the heads done by Larry.
Besides sinking the valves, it's possible that Gasser CNCs the chamber?
Great information, thank you!!
I could see that Wolf hand worked the chambers and ports. They may flow fine with a bigger bore, I just don’t know enough about flow to be confident, but I think that bc he designed the flow for a 107 I probably don’t need to expect them to perform well on a 124. Or does the flow/velocity pick up with a bigger bore? I would take them back to him this Winter, But he’s 1000 miles away now. I was just bringing the compression up and putting a larger cam like Wolf told me I should do from the start, now I’m all over the place!!
**also, I remember that he used a bigger intake valve
I have no input on which direction you should go, but I'd price new cylinders before you commit to trimming one down. Having a shop shave a little off isn't a big deal, but that much material you'll potentially be cutting the sleeve to make clearance for the crank
I am staying out of this one; lots of information for the OP to sort through; can't add anything. However, if the Gasser heads for a 107" motor flowed 250cfm @28", I would not be sending heads back to Gasser for re-work. Those heads should have flowed 275-300 from the jump IMHO. As has been said, WFO Larry, AKA, Larry's Motorcycle and Machine would be a good source to sort through the various options and make a decision.
That is what is confusing to me about flow, I read, “don’t get wrapped up in cfm numbers, it’s about velocity.” At the same time I hear a head should flow xxx cfm. The 107 made 120 Ft lbs with a little Andrews 57 cam, but fell off from there to I think 100 hp. He said the head pipe was too small. I put the road rage 2 on and did a pull at Sturgis this year, made 100 hp 108 torque. They said my head pipe too big now. Another reason I was considering adding some cubes this winter.
I’ll talk to Larry soon
Going from a 107 4 3/8 stroke, you're going to have to bore the cases. Might as well have someone do both the cases and cylinders at the same time.. At 4 1/8 bore with long spigots the spigots will need cutting for the oilers and cylinder to cylinder, clearance. I'd cut the spigots to the same length - a few thou, as sns specifies in there instructions..
Don Dorfman was thinking about sleeving stock cylinders and making a kit. That IMO, is too much work.
Don't compromise the outcome of your build because you have a part or two you want to make work...follow Max's advice and talk to Larry or Scott at hillside. A 107 with the right parts can be a great motor.
With 93 cc chambers, the cr is roughly 9.7 to 1 with a CCP of 185.. It's a pretty anemic build. It would be better at 10.2 to 10.4 but requires a good dyno tune.. A strong running 107 can make 125/125 but it takes good heads, 10.8 compression, good throttle body and exhaust. Not too hard to do better on a 117.
While I like smaller intake ports on a 95/98, once you hit 107, it is probably best to use 1.8 inch ports.
