Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I am in the hunt for it. The shop that did the original work is still around..
If the shop is still around they may have record of what they did, doesn't hurt to ask
If the envelope said Power Vision then the USB drive should at least contain the license file that was used to tune it. $220 it will save you when you go to get it re tuned, there is no value in the shop keeping the license because it belongs to the serial number of the ECM and any Power Vision can use it if the license file is applied to the Power Vision being used. If it has the tune file then even better. If you find the drive post up what the titles of the files are and we can help decipher what you have
