Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm trying to tune a 2020 lowrider S right now with the following build:
Fm 128" 11.0:1 big bore kit, fM
level b heads, Wood
Performance .600 lift beehive
style springs, woods 9f60 cam,
hpi 6.2 injectors, hpi 62mm
throttle body, fm ac de air
cleaner kit +1 oversized filter,
s&s cam plate oil pump, fuel
moto adjustable push rods,
woods alpha lifters, thrashin AR
exhaust.
It's being a real pain to tune and numbers so far are 137/138 with a really choppy graph and pretty soft on bottom. I decided to do a compression test on it and it came back at 184/182 (ACR's turned off in Map and throttle plate open). Does this seem really low to you guys? I don't know the specs on the build other than what I put above. CCP and HP/TQ all seem pretty low for the build, I'm kinda worried something may be off in the cam chest. Have any of you built something similar that can share what your CCP was? Big boyz calculator doesn't have the M8 cams and I can't find specs to manually add them to the calculator. Thanks for any help you guys can give.
Seems like 180 psi CCP used to be thought of as right in the sweet spot. For whatever reason these M8's run well with a lot more. The T-Man web page claims that the stock CVO 117 engines have a CCP between 230-235 psi. That used to be unthinkable.....
It seems unlikely but maybe you missed by a tooth on the cam chain?
I'm really wondering if that's the case. Owner did the assembly himself and I believe this is his first HD engine.
Another 'Hail Mary' guess, pushrod adjustment is leaving one or more valves ever so slightly open? It would be nice if somebody with a stour 128 like yours could chime in with their HP/Torque numbers. Maybe you're numbers are 'as expected'?
level b heads, Wood
exhaust.
Out of curiosity, who assembled the engine?
Ring alignment wrong? Rings still not seated? Was deck height checked? Someone use a +4 -4 crank sprocket? Maybe a leak down test would rule out cylinder, rings,barrel and valve issues.
Owner assembled it. All I can figure at this point is just a bad combo. I pulled cam cover and the gears are in properly. Leak down was 1 to 1-1/2% front and 1% rear. I can find nothing at all wrong with it. I'm thinking it's a poor choice in exhaust and the engine just doesn't have enough mechanical compression to support that cam .
