Assembly lube question
Old Jan 5, 2023 | 09:09 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default Assembly lube question
I'm going to be starting a stage 2 on my bike in a couple of months. I have most of the parts in my possession but still need to pick up a few more things. One item is assembly lube. I will be slow with this project, I may finish the cam chest and then may not get the exhaust on until the next weekend. Overall I may have to spend two or three weekends getting the job done. I will need a assembly lube that will remain and not drip off or run away. I have no experience with assembly lubes, what would you recommend?
Old Jan 5, 2023 | 09:21 PM
sanman4ever's Avatar
sanman4ever
Permatex Ultra-Slick Engine Assembly Lube 81950
Old Jan 5, 2023 | 09:57 PM
PeterB's Avatar
PeterB
Any good brand assembly lube will do what you want. That is what it is designed for. It is a thick goo that stays put until you start the engine.
And for what you are doing it is not even essential. It is primarily for surfaces that rub hard together, like flat tappets on the cam lobe. With roller tappets like a Harley, its use is moot. A bit of oil will do the job. And the needle roller bearings are best lubed up with a squirt of oil before assembly. Needle rollers don't really like thick lubricants. Same with the gears, sprockets, chains etc in the gearcase. Bit of oil is all they need.
I wouldn't sweat it too much. Whatever your local store has will work.
Personally, I mostly use oil or maybe a smear of black moly grease on things like bronze bushings.
Old Jan 5, 2023 | 10:26 PM
PureHybrid's Avatar
PureHybrid
Agree. Soak it in oil, it'll be good
Old Jan 5, 2023 | 10:35 PM
TwiZted Biker's Avatar
TwiZted Biker
Old sleeve bearing engines I used STP, older guys in here will know what that is. Harley engines good oil straight 50 wt motor oil.
I've used various commercial assembly lubes and haven't seen a bit of difference in the end results. Only time I do now is if it comes with the parts from the manufacturer.
Old Jan 6, 2023 | 07:31 AM
dontdropit's Avatar
dontdropit
Back in the 80s dune buggies ( but built a little stronger and called woods buggies here in KY). When we worked on the vw engines we used stp. It did the job back then.
Old Jan 6, 2023 | 11:56 AM
tdrglide's Avatar
tdrglide
What I do
Anything in the cam chest - whatever motor oil you're using in the oil tank/pan
Rocker boxes - If new assembly, Torco assembly lube
Old Jan 6, 2023 | 08:13 PM
NorthWestern's Avatar
NorthWestern
Engine oil will work fine, I have built quite literally hundreds with Mobil Delvac 15w40, or Delo 400, and many have gone straight into storage with no ill effects after being put into service.
My personal stuff; straight 40 weight for years, and more recently Lucas Assembly Lube
You should be fine with just about any engine oil, or assembly lube that you find on the shelf.
Old Jan 11, 2023 | 10:46 PM
60Gunner's Avatar
60Gunner
No wrong answers here but I've using this
Redline Assembly Lube Redline Assembly Lube
forever with no reason to change.
Gizmo83
Milwaukee Eight (M8)
41
Nov 6, 2023 12:00 PM
Low..Ride..errr21
2018+ Softail Models
18
Mar 20, 2022 04:39 PM
Sarge Fatboy
Twin Cam Motors
Jan 13, 2022 02:09 PM
Bikes and Boards
Nov 23, 2021 05:33 AM
tcatnat
Aug 19, 2011 07:01 PM
