Adjustable pushrod advantages
Old Apr 5, 2017 | 11:02 AM
DieselDummy's Avatar
DieselDummy
Default Adjustable pushrod advantages
What is the advantage of using them?
Thanks
Old Apr 5, 2017 | 11:15 AM
martinj's Avatar
martinj
Not having to remove the rocker covers/rockers to do a cam change, plus being able to optimize the lifter preload.
Old Apr 5, 2017 | 11:41 AM
danzio's Avatar
danzio
If you have access to a pair of bolt cutters a cam swap with adjustable push rods becomes a pretty easy job. IMHO.
Old Apr 5, 2017 | 11:59 AM
DieselDummy
Thanks, bought for my build but didn't get the tubes so couldn't get inners adjusted so put my SE pushrods back in. Gonna get right tubes eventually but didnt know if I was leaving power on the table by not using them.
Old Apr 5, 2017 | 04:43 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
There is no need for adjustable pushrods on an engine with hydraulic lifters.
I keep reading the one about making cam swaps easier, seriously; how many cam swaps are you going to do?
Old Apr 5, 2017 | 05:07 PM
ntraindavefl's Avatar
ntraindavefl
I hope w your "build" the valvetrain height is same as stock.
Or the solids work with your build set up.
Old Apr 5, 2017 | 05:26 PM
martinj's Avatar
martinj
Here's a scenario: You're replacing a stock cam with a cam that has a smaller base circle, and replacing the stock .045" head gasket with a .030" head gasket. You've just reduced the pushrod length needed for optimum lifter preload. Add to that a new set of lifters that may require a bit more or less pushrod length, depending on the effective length of the lifter, and the scenario gets more complicated. Plus, if I recall, H-D sets lifter preload somewhere around .100" at the factory, which may or may not make for a quiet (a relative term) valvetrain. I've heard performance shops suggest anywhere from .125" to .140" preload for a quiet valvetrain. See where I'm going here?
You have a couple of choices: One, order a set of correct-for-your-combination nonadjustable pushrods (which could take a while to arrive-not to mention the procedure required for correctly measuring for the proper length) or, Two, use a set of adjustable pushrods, follow the correct installation procedure, and have your bike running the same weekend, and with the optimum preload.
The other scenario: You want to do a simple (again, a relative term) cam install, you have the weekend to do it in, and you don't want to pull the rocker covers or rocker assemblys. The solution: use adjustable pushrods. Just cut the stock ones out with bolt cutters, and install and adjust the preload on the new adjustables.
No need for adjustable pushrods? Maybe not. But they sure can make things quicker and easier. And, if properly done, there's no real liability, except for the added cost. But then again, time is money........
It's just like everything else in life, you can do it the hard way, or the easy way. Which is hard, and which is easy, is up to the individual.
Old Apr 5, 2017 | 08:20 PM
DieselDummy
valve train height has not changed, and it runs fine
Old Apr 5, 2017 | 08:37 PM
Taggs's Avatar
Taggs
Not always the case. There are other reasons to open the cam chest on v twins causing pushrods to be pulled. Cam plate upgrade, cam bushings, tensioners,ect. Whatever the case may be for this sort of service will result in a simplified repair both present and future.
Old Apr 6, 2017 | 05:30 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
An adjustable pushrod allows the PROPER lifter pre-load, in spite of factory pre-load specs, to help insure quiet engine operation, at full thermal expansion.
Base circle, re-surfaced heads, longer/shorter cylinders are all other large reasons for their use.
Scott
