Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
If at this point the crank does need work why not just stroke it with an S&S????
This.
Reaper (2005 Night Train) developed a rod knock after over 217,000 miles on her original, unopened, bottom end last October. When she comes out of winter hibernation, she'll be sporting a 107ci engine with an S&S stroker crank, and Timken bearing upgrade. Once you have to split the cases, you may as well go all in, IMHO.
