SE adjustable pushrods.
Old Mar 27, 2023 | 07:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by paud
IS this really normal?
Absolutely not.
Old Mar 27, 2023 | 08:08 AM
Uncle Larry's Avatar
Uncle Larry
Normal ?? Seriously you can't be serious can you?
Old Mar 27, 2023 | 08:54 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Old Mar 27, 2023 | 09:15 AM
harleybob815's Avatar
harleybob815
and...now I'm scared to death of collapsible pushrods!
Old Mar 27, 2023 | 12:00 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Old Mar 27, 2023 | 02:55 PM
pgreer's Avatar
pgreer
A fixed length pushrods that fits properly is hard to beat, except it does require removing the rocker boxes to service them. But even with component changes or modifications, the need to adjust the pushrod length can be necessary.
Consider what happens when valves and seats are cut when performing head work, in relation to the pushrod length. Or thicker / thinner head and base gaskets, cutting the head or cylinder gasket surface to true them or that some cams have a different base circle. The easiest way to resolve that is to have adjustable pushrods.
Some pushrods are better made than others. You can always have pushrods made for your needs. I've run S&S Quickies and V-Thunder ones with no issues. Smith pushrods in Bend Oregon is well known for high quality pushrods and are well known for racing engines. They have pushrods for HD engines and can custom build to your specs. So there are options, but they should be straight.
Paul
Old Mar 28, 2023 | 09:51 AM
470004's Avatar
470004
It looked straight to the company that made them for the MOCO.
Old Mar 28, 2023 | 05:29 PM
paud's Avatar
paud
Took the bike to the dealer for complete diagnostic. Good and bad news...sort of. Good news is, techs said I did a very good job of installing everything. Sort of bad news...I was actually lugging the bike. In an attempt to save gas and some noise, I would be at 65 to 70 in 6th gear. Ok for straits and down hill, but NOT for twisting the throttle. The rpms around that speed were just below 2000 with the torque cam. SO, retraining myself to only twist throttle if well about 2500, and close to or a bit above 3000 +
buick455gs
Screamin Eagle CVO Models
Jan 6, 2008 03:47 PM
jakazz
Apr 8, 2007 08:22 PM
rollover
Feb 9, 2007 07:05 PM
back again
Jul 28, 2006 09:53 PM
rdf24
Dec 24, 2005 11:02 PM
