Valve Stem Tip
Old Apr 11, 2023 | 06:32 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Curious if it did anything to the hardness of the tip..
Old Apr 11, 2023 | 07:28 AM
skydude426's Avatar
skydude426
I don't think so. It is definitely hard and not easy to remove material from. I also did it slow and easy, not to heat it up. It was always cool enough to touch.
Old Apr 11, 2023 | 08:14 AM
wfolarry's Avatar
wfolarry
It's not worth grinding the tip for .015". Your rocker arm geometry is not going to be a problem.
If the tip isn't ground square it will wipe out the rocker arm, valve or both.
Old Apr 11, 2023 | 08:22 AM
skydude426's Avatar
skydude426
Too late, its ground and I'm confident that its square. I get anxiety over small details, if I didn't think it was square and smooth, I wouldn't use it.
Old Apr 11, 2023 | 09:14 AM
bustert's Avatar
bustert
what was the original issue???
was this a new valve?, old valve after a seat repair??
if this was a recession issue, the repair although worked, did not solve the base issue.
the valve material is pretty much hard all they way through, UNLESS, it is a sodium filled valve which if done will destroy your engine when it breaks like glass.
yep, saw dust in the ole rear end will quite her down, at least till the bearings fail.
keep money in your pocket and the cell charged just in case you are on the highway.
Old Apr 11, 2023 | 09:27 AM
skydude426's Avatar
skydude426
After having the valves and valve seats ground, the stem protrusion was out of spec. It should all be good now.
Old Apr 12, 2023 | 08:06 AM
bustert's Avatar
bustert
hummm????
a band-aide fix
sure you can get by just like running a piston in a .008 taper hole, but, issues follow. depending upon the head setup, you could induce valve shrouding and flow issues.
your dollar but for me, new seats would be the ticket.
i will tell johnny to warm up the western flyer and oil the pedals.
Old Apr 12, 2023 | 08:08 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by Rusty Springs
I used to grind valves when I worked in a machine shop. Part of the process was grinding the tip of the stem to make it flat again. It can be done but not with the valve in the head.
I'm not familiar enough with these engines to say what will or won't work. .015" isn't much but specs are there for a reason.
I've done some shady **** with a buffing disc on die grinder on large diesel engines. Harley engines seem too delicate for that kind of thing.
It can be done but not with the valve in the head ... Someone out there right now is thinking "Why not?"
Old Apr 16, 2023 | 10:32 AM
soarguy's Avatar
soarguy
Hold on... if a valve job was done RIGHT, the installed stem height should have been accounted for and set. Sounds to me like the valve seat was ground too far, which will let the valve head sit too far into the head, which means the valve stem is now too tall. I'd go back to the machinist and ask if he thought of that...
Old Apr 16, 2023 | 10:51 AM
Tired's Avatar
Tired
I can't imagine any reputable machinist that wouldn't. Reputable being the key word.
