Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I assume this is because you are having difficulty engaging the center pin of the Schraeder valve to pressurize the tire.
But, why would a valve stem be produced that was 0.015" too long?
I suspect that the pin on the valve itself, or the pin on your chuck may be the real issue (assuming the tire is hard to fill).
OR...
The valve is threaded 'in too far'... (if that is even possible).
To answer your question, I cannot see any reason that shaving off 0.015" would cause you any issues.
At 0.015, run it.. Heck if going to higher lift cams it may be good.. 0.050 might be an issue.. Really need to know what heads and valves..
BTW sometimes you can get shorter valves. AVnV makes a 1.900 intake that is 0.040 shorter than stock. It allows for sinking of the valve into the head to get valve to valve clearance..
I used to grind valves when I worked in a machine shop. Part of the process was grinding the tip of the stem to make it flat again. It can be done but not with the valve in the head.
I'm not familiar enough with these engines to say what will or won't work. .015" isn't much but specs are there for a reason.
I've done some shady **** with a buffing disc on die grinder on large diesel engines. Harley engines seem too delicate for that kind of thing.
I did some shady **** with an angle grinder last night. I used a new fine cutting wheel and mounted a piece of angle aluminum on the grinder using the threaded handle mounting hole, which I mounted as squarely to the cutting blade as I could. I rotated the valve as I slowly ground a little off and kept checking the length. It never got hot as I could always touch the end without getting burnt. After grinding it I would hit it up on the wire wheel to remove any burrs and polish the surface. It was a slow process, but I removed enough to get it within the spec of 2.025" - 2.069" for 7mm valve stem protrusion.
It worked well. I can't tell anything has been ground off by looking at it and if I use a machinist's square and hold it up to the light, it's as squarely cut as the valve I did nothing to.
