Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I've been glass bead cleaning motorcycle parts for over 40 years & never had a problem.
Do you glass bead on the insides of the cases etc.?
I guess it all depends on the clean up eh? A guy could use a power washer and/or dishsoap/laundry detergent along with compressed air? Should be ok?
I'm still shopping for a blast cabinet etc. and some media. I might go with whatever media entails the least spending.
Thanks for your input.
Well it's been over 2 years since the OP started this thread.. If he did bead blast his cases maybe you can private message him to find out how they're holding up??
I was told years ago that the inside of the shovel cases are porous and bead material will inbed in the porous cases.. Pretty sure it was @johnjzjz , he lives in the Shovelhead section.. Maybe you should post your questions over there..
There seems to be quite a variation on the bottom line for blasting internals. I started my own BLASTING THINGS thread recently. Maybe I'm spreading out too far. I have communicated with @johnjzjz on the shovelhead build I started 1976, 74cid Close to Stock Engine Build. I will run the glass bead/cases thing by him too. Thanks
I am the OP and I bead blasted the inside of the cases but the washed with soap and water afterwards.
Running great. Oh and I also Glyptal paint he insides after washing so any beads would be painted over and sealed.
Since old Harley engine and trans cases are so porous I always Glyptal.
Fantastic! Thanks for getting back.
If I go with glass bead, or anything other than soda I like the idea of powerwashing the cases, and then handwashing with detergent and a brush to help clear any residual. I plan on using Glyptal too; that could seal in anything residual in the aluminum; good logic. I hope I can get some Glyptal Red from Westburne electrical supplies in Alberta.
