Pushrod Length?
Old May 9, 2023 | 02:30 PM
blackgt85's Avatar
blackgt85
Default Pushrod Length?
Looking to get regular, solid pushrods for my combo, but don't know what size. I have a 06 88" with a Fuel Moto 98" big bore kit, S&S 79cc Super Stock heads, Wood TW555-6R cams and the Cometic MLS head gasket that comes in the kit from Fuel Moto. Not a fan of the adjustable pushrods. Does anybody know (and have experience with) if the stock pushrods will be fine with this combo? Thanks.
Old May 9, 2023 | 02:57 PM
MattLS6's Avatar
MattLS6
Different cylinders, heads, gasket thicknesses, cam base circles, milling/decking, etc. can and will alter the proper pushrod length. Even then you've got lifter brand A that wants more or less preload than lifter brand B. The likelihood of the stock pushrods being the ideal length is slim.
The easiest approach is going to be adjustables. I wasn't very comfortable with the thought of adjustables but then I gave them a go and have been installing them in my Harleys ever sense. I only run 1 piece pushrods in my cars so I'll share how I measure those.
You can buy adjustable pushrod checkers from Comp Cams, etc. I mark the valve stems with sharpie, set pushrod checker to a length I expect to be close, set rocker to zero lash and roll motor over a couple times. Remove rocker, examine wipe pattern on the valve stem. I'm looking for a thin line right in the middle of the valve stem. Takes some trial and error and sometimes a decent amount of time. Once I determine the proper length I buy the pushrods in that length and toss em in.
*I've never done the above process on an HD, just sharing for awareness/ideas. It has worked well for me with Chevy SBC and LS motors.
Old May 9, 2023 | 03:27 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Every build is going to be different and you're not going to be able to use a standard length pushrod unlike the Evos... You'll have to use a set of adjustable pushrods and then take all the rocker assemblies apart and then measure the push rods and then call Manton in California and they'll make you up a set. In all honesty it's not worth it, don't waste your time..
Old May 9, 2023 | 03:31 PM
M Oclaf's Avatar
M Oclaf
Why is this claim that only EVO’s use standard length pushrods? Wouldn’t current M8’s have adjustable pushrods?
Old May 9, 2023 | 05:29 PM
98hotrodfatboy
I have no idea I'm not a M8 person.. I've dealt with twin cams and Evos and if you want to use stock push rods return everything back to stock lengths.. That's all I'm saying. Adjustable pushrods are for one reason, whenever you change cylinder heights or resurface cylinder heads or go to thinner head gaskets all that changes preload with a stick pushrod and not to mention when you go to cams with higher lift with smaller base circle diameters, even that adds to it all..
All's I'm saying is that when you remove yourself from a stock configuration it's not as easy to go to a stock length pushrod or solid pushrods... It's a little bit of work and they're not always accurate..
Old May 13, 2023 | 05:58 AM
skydude426's Avatar
skydude426
There’s nothing wrong with using quality adjustable pushrods. In fact, it’s necessary if you alter your engine from stock configuration. You can get custom lengths but you’ll need to set and measure an adjustable pushrod to find out the lengths you need in your build.
OP, I’m curious as to why you’re reluctant to use adjustable pushrods?
Old May 13, 2023 | 08:29 AM
fat00boy's Avatar
fat00boy
You need to use lightweight checking valve springs that don't compress the lifter. Then add the .140 ( or whatever preload ) to the pushrod length. It's the narrowest sweep you're looking for, not always dead nuts center.
Old May 13, 2023 | 08:56 AM
60Gunner's Avatar
60Gunner
Solid pushrods are a better pushrod. Adjustables have their advantages but there's no doubt solids are better. I have had this conversation with Smith Brothers and other manufacturers who make both and all will tell you solids are a better, lighter weight, no flex, pushrod.
To get them custom made to the correct length use an adjustable and install/adjust to the desired preload then measure the length. I suggest a preload of .140. Not the stock .100.
You could do all the math of cam base circle, head gasket thickness, amount milled from heads...blah blah. But the best, most accurate way is to use an adjustable then pull the heads again to install the solids.
Yes, changes to configuration may require new ones again and cam changes will require the heads be removed. If you wanna play ya gotta pay.
I seriously doubt anyone in the performance world would even think about using an adjustable pushrod. I know of one that would laugh at the idea. Does it matter for most here? Probably not. Unless you're **** about this kind of stuff.
I can tell you if I ever pull my heads again I'm having solids made. Call me ****.
Old May 13, 2023 | 08:32 PM
MotoJockey's Avatar
MotoJockey
Have you had any problems or failures with your adjustable pushrods?
Old May 14, 2023 | 11:33 AM
60Gunner's Avatar
60Gunner
I had one come loose. I was only blocks from home when I heard it and didn't do any damage. I'm still running them(S&S Quickies). I've never been a fan of them. I get why everyone likes them and I like the convenience of them. Solids are still better. Lighter weight for same or better strength that require more work.
If you're fan of them I'm not here to change your mind. The OP stated he's not a fan of adjustables and there are reasons for this. I don't think he's looking for to have his mind changed.
https://www.cyclesolutions.com/produ...iece-pushrods/
