Troubleshooting Puzzle
Old May 22, 2023 | 01:57 PM
pleasants9's Avatar
pleasants9
No colored smoke coming out the exhaust pipe when I rode it and the no residue sitting in the pipe also, it is a little "carbony" in it though.
Old May 22, 2023 | 02:16 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by pleasants9
Took the front head off just to be thorough and no sign of anything suspicious, the seal didn't look like anything had blown through. When I rebuilt the motor I tried to tune it myself but I'm starting to think I did not do a sufficient job. there was a little bit of fluid sitting in the port of the intake valve when I pulled off the intake manifold. I think I have two issues.
1) The front exhaust manifold was loose which caused the leak
2) Bad Tune, I think the motor has been running super rich which has resulted in excess carbon and unburned fuel.
Pics of the valve and piston (The scratches on the piston are from me, dropped a small washer down the spark plug hole and had to fish it out with a screwdriver I magnetized..)
snip
front head underside
snip
Front piston at TDC
I think I'm gonna put it all back together, verify torques then take it to a shop to tune since I did a bad job. Maybe also lean out the Mikuni carb?
It wouldn't surprise me that you are running too much fuel and too much timing.. I suspect that you'll need to find someone that has built a similar motor.. Not sure where you got the build parts from but I'd think that Hammer Performance should be able to suggest timing and jetting.
Since the head is off, I'd replace the valve seal.. Check clearance on the valve stem.
Old May 22, 2023 | 02:20 PM
Max Headflow
Btw, It may be leaking around the guide. Notice that the exhaust port looks a lot better.
Old May 22, 2023 | 08:02 PM
pleasants9's Avatar
pleasants9
I had all my work done by NRHS but I just discovered they closed shop back in 2020 (I was living in Japan the last 2.5 years) Anyone know of a good machine shop in the San Diego, Ca area? I think it's worth having the heads looked at by a pro?
martinjstn1
Exhaust System Topics
Jan 14, 2021 11:56 AM
panz4ever
Panhead
Jun 28, 2020 03:27 PM
strych9
Milwaukee Eight (M8)
66
Aug 22, 2018 12:42 PM
Nick Sorgio
Shovelhead
13
Apr 18, 2017 08:55 AM
RRTX_FSTLN
Shovelhead
Oct 11, 2014 02:47 PM
