O2 sensor & heater control circuit codes
Old Jun 20, 2023 | 04:22 PM
cj.nagel1's Avatar
cj.nagel1
Default O2 sensor & heater control circuit codes
So the other day went for a pretty decently long ride, bike was running great everything was great, got home and parked it in the garage. Yesterday I installed a new amp, speakers and turn signals so I had the battery disconnected at the time.. I’m running Power vision 4 tuner with tunes from Fuel Moto but I thought this morning I’d take the bike to work so before I left I figured since I had the battery disconnected I’d reflash my tune onto my ecm quick, it’s just what I do every time I have the battery disconnected just in case it resets the ecm (I don’t know if it actually does or not) just as a precaution, flashing the tune went good but as soon as I started the bike my engine light came on, went to the diagnostic screen on the PV and had 4 codes, P0154 (inactive) rear o2 sensor open/not responding, P0134 (inactive) front o2 sensor open/not responding, P0051 (inactive) rear heater control circuit o2 sensor low/open, and P0031 (inactive) front heater control circuit o2 sensor low/open.. took it for short ride to see if it’d come out of it but it didn’t and now it’s running really rich, anyone know what would be the cause because I’m absolutely lost, all connections look fine and tight, no broken wires anywhere that I’ve seen, should I try to clean the o2 sensors? And if so could I use anything to clean them with like break clean or is their something in particular I should use, I just can’t figure out what’s causing the codes.. thanks in advance
cj.nagel1
Jun 20, 2023 04:21 PM
cj.nagel1
Exhaust System Topics
Jun 20, 2023 04:20 PM
RustyCage
Aug 10, 2015 12:21 PM
hdkev
Aug 12, 2014 12:41 AM
Touring Tom
May 12, 2009 10:10 AM
