Splitting the crankcase on a m8
Old Jul 13, 2023 | 09:29 PM
60Gunner's Avatar
60Gunner
Originally Posted by brickle
that is a steal for sure. I already looked into doing a s&s crank and after buying a big bore kit, it hurt to see the price.
Yeah they went up like $500 about that time. I remember he had to really look and buy one back from a vendor because they were backordered and he told me the price was going up on them big time.
I'd have to dig up the receipt but it was around $1100, maybe a little less for the crank as I recall. And that was his cost.
Old Jul 13, 2023 | 09:31 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I went through the same issue, cam bearing came out in pieces, same tool as OP used.
I split the cases to look for debris, but the cases were clean.
To split the cases I used a brake caliper piston spreader tool.
Pulled the piston oilers, replaced the gaskets and reinstalled them.
I did not replace any bearings in the crankcases, no reason to.
Used the Harley brand sealant and reassembled.
Old Jul 14, 2023 | 04:29 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Not entirely true, I did replace the cam bearing...
Old Jul 14, 2023 | 08:33 PM
Max Headflow's Avatar
Max Headflow
Since the inner cam bearing was destroy doing cam work and the motor not run, no reason to replace the crank bearings if mileage is low. As alway inspect, if they look questionable replace.
tankthebiker
Engine Mechanical Topics
11
Jan 4, 2021 02:52 PM
SiggerTX
Jan 3, 2016 09:22 PM
Carbo
Feb 14, 2013 09:01 PM
redmosquito1
Oct 3, 2012 08:07 PM
rkoivisto
Sep 25, 2011 08:47 PM
