89 evo Clutch basket wobble
Old Aug 9, 2023 | 11:35 PM
Decks's Avatar
Decks
Stage I
Default 89 evo Clutch basket wobble
Spin the clutch hub and the clutch basket wobbles
clutch hub is new drag specialties
old bearing was pressed out new bearing pressed in
vibrations from this wobble are breaking bearing
wobble is present with basket and hub removed from the main shaft
bearing is fully seated we removed and repressed bearing twice my old stock oem clutch hub did not have any wobble starting to think the drag specialties hub is defective
Old Aug 10, 2023 | 11:24 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I would mount the hub to the trans shaft to check for play between the hub and shell (bearing ) then check runout at starter Ring gear..
moto4sho
26
Oct 16, 2023 08:41 AM
Elecglide
EVO
Jun 26, 2020 08:22 AM
blackbear
EVO
Jun 28, 2013 11:07 PM
DJ Baar
Oct 5, 2011 10:49 AM
JustDave71
Aug 20, 2010 08:17 PM
